Oil question
crazykid1994
Been doing some research on the improved racing filter relocation. They use -10orb fitting instead of the transdapt 1/2”npt fittings. And have an optional -12an fitting setup. I’m debating on doing that with mine if anyone wants to purchase my transdapt setup cheap used. You’ll need new hoses. Fittings are reusable. I’ll be going back to a stock 22x1.5 filter setup over the 3/4-16 filter setup.
David James
Fredericksburg, VA
I went to get my oil changed and bought 5 qtrs. Mobil 1 75000 mile full synthetic oil, and a quart of extended performance synthetic oil. I thought that I could have the best of both worlds, but the technician told me they aren't allowed to mix oil types, which I can understand but also stated that mixing different oils can destroy your engine. I was wondering if anyone knows the facts about this and whether the technician was right. I can understand mixing different SAE ratings or mixing synthetic and non-synthetic oils, but mixing two of the same brand, same SAE rating oils that just have different additives? Any info would be helpful and appreciated.
Also, a little off topic, I have a 2014 ram 1500, 5.7L. I strictly use Mobil 1 full synthetic brand engine oil. Are there any better brands? Or rather, is there really any difference between Mobil 1, Valvoline, Pennzoil etc.?
Thanks!
Unless you’re a chemical engineer specializing in lubricants, just buy a correct specified oil and use it in consonance with a good quality filter. Mix and match probably waste of time. I do lab analysis every 50 k and use on sale OEM spec synthetic oils, 5 k oil changes, and the additive packages are always only about 35-40% used at that point, no degradation. Works for me. 5.7 Hemi, 2016, working north of 100 k trouble free miles.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Best you read up on Hemi lifter and cam failures before making boilerplate lubrication statements for all engines.
