Payload and Towing, Information and Where to Find It
OC455
Central NY
Maybe this can become a sticky, not going to give any opinions or conjecture. Just a start where to look stuff up to find cargo & towing information.
This is the location of the cargo capacity sticker on the driver's side door jamb.
This is what it looks like and has the cargo capacity listed in Kg and Lbs.
This sticker lists the information for your truck, VIN, axle ratings and Gross Vehicle Weight. This is on the driver's door.
Curb/base weight can be figured out by subtracting the cargo/payload from the Gross Vehicle Weight.
Using the info in the two images, 14000 - 6292 = 7708 gives you the curb/base weight.
To find out what equipment you have for your truck, you can check here:
This will also give you the gear ratio for your truck.
You can find your towing capacity by looking here:
Enter your VIN and see what is listed. It only goes back 5 years I believe.
Another way of checking your tow rating, is by looking up your truck on the Ram Trailer Towing charts. You have to know your gear ratio. Using the chart, the example has a 3.73 gear ratio. Mega cab dually, 6.4L Hemi, 3.73 gear ratio, 4x4, has a Gross Combined Weight Rating of 21500 lbs. Subtract the curb/base weight from the Gross Combined Weight Rating to find the tow rating.
21500 - 7708 = 13792.
2019 Trailer Towing Charts:
RAM 1500 Classic:
RAM 1500 DT: https://www.ramtrucks.com/BodyBuilder/service/Image?imageId=MtQrP/FqLY5r/est8MtGjGgHzAHGUTU0WB3rWuqSY7YmQ2vEhuBWBAvoEbjA+c5q
RAM 2500: https://www.ramtrucks.com/content/d...ow_Excel_2019_DJ_OFFICIAL_INTERNAL_2-6-19.pdf
RAM 3500: https://www.ramtrucks.com/content/d...w_Excel_2019_D2_OFFICIAL_INTERNAL_2-06-18.pdf
RAM 3500 4500 5500 Chassis Cab: https://www.ramtruck.ca/en_dir/pdf/Ram_ChassisCab_TowingPayload_Chart_EN.pdf
2020 Trailer Towing Charts:
RAM 1500 Classic:
RAM 1500 DT:
RAM 2500: https://www.ramtrucks.com/content/d..._HD_2500_DJ_Trailer_Tow_Weight_Chart_MY20.pdf
RAM 3500:
RAM 3500 Chassis Cab: https://www.ramtrucks.com/content/d...g/Ram_CC_Trailer_Tow_Weight_Chart_MY20_R1.pdf
RAM 4500:
RAM 5500: https://www.ramtrucks.com/content/d...g/Ram_CC_Trailer_Tow_Weight_Chart_MY20_R1.pdf
2021 Trailer Towing Charts:
RAM 1500 Classic:
RAM 1500 DT: https://www.ramtrucks.com/content/d...am_LD_DT_Trailer-Tow-Weight-Chart_MY21_R1.pdf
RAM 2500:
RAM 3500:
RAM 4500:
RAM 5500: https://www.ramtrucks.com/content/d...wing/Ram_CC_Trailer_Tow_Weight_Chart_MY21.pdf
2022 Trailer Towing Charts:
Still searching for the ramtrucks.com trailer towing charts for 2022.
tron67j
Maryland
Thanks for doing this. Now. Will people go here first?
Also to consider is what aftermarket options one has added to their trucks. The weight of aftermarket items like running boards, bedliner, tonneau cover, back rack, front bumper guard, etc. are subtracted from your payload capacity. Best thing to always do when trying to figure out what you can tow is load your vehicle up with everything you would normally have in it, including people and gear plus your hitch system. Then go weigh it and subtract that from your GVW for available payload capacity.
MADDOG
Out Exploring Arizona
Great info. People have to remember to weigh their loaded truck, compare that with their GVWR and be mindful of the difference which is your actual payload.
Having only 1500 pounds payload left and expecting to add 2500 pounds in fifth wheel pin weight just won't work out well.
OC455
OC455
Central NY
All points you make are excellent....this is more for folks that are either new or do not know how to or where to get the information they need as the truck rolls off the lot. I'll try to keep this updated the best I can gents.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Where does someone go to get their vehicle weighed?
An auto junkyard, Concrete recycling yard, sand pit, all usually have a scale and if you ask they don't care if you weigh your truck , just don't interfere with operations. Not that it matters, most will tell you it is not a certified weigh like a CAT scale that you pay for.
tron67j
Maryland
I keep seeing questions about towing where there is sag, or the trailer sways, or such. Often these posts are a lead in to questions such as "Should I get air bags" or " Will helper springs work".
Under no circumstances can anyone in this forum provide suggestions that could provide good for thought to help unless you first weigh your fully loaded truck. Then the fully assembled rig with weights of entirety, front truck axle only, rear axle only, trailer tongue weight, trailer axle weight, and full trailer not attached to truck. If your rig is overweight the answer is always going start with the cheap answer; lighten it all. Then you move into costly 2 options of get a smaller trailer or a bigger truck. There is no other option.
If within weights and you have sag then either a WDH and/or repair suspension with stock parts are generally the only answers with one additional consideration, which is distribution of weight in trailer is off BUT that does not mean just move stuff to the back but rather balance it better.
If steering or braking is off and axle weights are good, you need suspension work or maybe different tires.
There is obviously more to this all. The point is to not ask for agreement that you should buy helper springs, etc. unless you bring numbers to your post. There are a lot of knowledgeable people here but in the end our advice is not nearly as valid as a trusted mechanic or hitch specialist who actually will investigate and diagnose the exact problem and recommend corrective action.
Please, get your actual (not theoretical) weights first! Oh. And provide exact numbers from door jamb and from your VIN lookup.
OC455
OC455
Central NY
This thread was just for that purpose. No conjecture or opinion.
metro ATL
Did RAM get rid of look up towing capabilities by VIN#? I cannot seem to find it anymore.
gofishn
Iowa
hemi 5.7L, 345 cu in
no one can fidn it. nto sre if it sis gone for good or site updates.
Administrator
Google: SAE J2807 for the year and truck your looking for. You'll find the PDF listing all the truck configurations with ratings per config.
metro ATL
@crash68 A solid way to look it up.
I'm new to most/almost all of this, so I wanna say what my mistake was that I caught about ratings. I assumed, that I could load my truck up to 11,400lbs, and max-tow 16,780lbs. Then, I kept seeing my truck's GCVWR as 21,500, but this was for normal gears. My truck's GCVWR is 24,200 and, if I take away 16,780lbs, I now can only have 480lbs of payload. However, I got options that weigh an extra 300lbs. I have no plans for max-tow, but at least I know I could, because I weigh 185 +/-3.
My concern was that my ratings changed as I've heard/read has happened to 2500's and other brands. When I couldn't find "look up ratings by VIN#" on RAM's site - I started to really question my ratings. Currently, my 3500 hasn't changed any weight capacities from its beginning. My concern became driving the truck very close to the GCVWR. 10,500 in truck weight with gear & occupants and 10,500 for trailer & cargo - I feel, it's safe to say, it'd be about 200lbs more than I thought - so that's 21,200 of the 21,500 I would've been allowed.
This site has helped me a lot with my journey. Being able to use and understand the GCVWR, PL, Max-Tow, CW, and their correlation to each other happened here. Getting great advice on what model I needed also came from here.
Thanks y'all. Enjoy the day.
Kdog57
