Voltage Etorque
Limited Ram
Australia
Trying to get some answers on etorque.
21 1500dt was dead flat and I replaced battery with a new type of Agm.
Firstly the manufacturer states its for that model but while running it only shows a charge around 12.9 v . I'm sure the old lead acid was higher so is this a concern?
Secondly because of this low voltage my duel battery sensing module won't kick in till 13.2 v .
Any helpful answers appreciated
Administrator
The eTorque system battery is 48V but it is capable of charging the 12V battery. The ECM controls the charging voltage to the 12V battery, but the 12.9V is a bit on the low side. There is a Intelligent Battery Sensor on the negi battery terminal that determines battery charge level for the ECM. You probably need to have a dealership check the charging system.
yakalong
KC
Did you drive it at higher RPMs? If so what was the voltage then?
