Matteo
So I've been searching around for a while and had found a couple similar situations others have had but their solution has not solved mine yet.
My headlights had been intermittent for a bit where they would work for a while, then they wouldnt work for a while to the point where they would flicker and then stay out.
my running lights would still work, my high beams when held, would stay on, but my low beam headlights would not come on still.
I replaced the headlamp switch as it seems to be a common failure but i am still having the same issue.
I have the entire dash apart and have found that it seems there is a loose wire possibly because when i have my headlamp switch turned on, the running lights are on, but the buzzer does not stay on constantly (engine off) like it usually does to remind you to turn your lights off. sometimes when i move the harness it goes on and off.
in short, my headlights wont stay on.
I have been unwrapping all the factory harness's in the dash and have yet to find a bad wire/loose wire.
any other ideas what i could be looking for??
im lost even with the factory wiring manual.
