Next power mod? Advice
Ausram
Cummins 6.7
Hi,
I'm from Australia and I'm after some info/advice on what I should do next. I have a 2009 6.7 ram 2500 I have already done a 4" exhaust, DPF & EGR delete, S&B intake and a XRT pro tuner. What would be the next step? I have been looking at intake horns, turbos and possibly changing the tuner?
Thanks
A
Ausram
Cummins 6.7
What do you think about doing a grid heater delete, is it worth it?
Power247
High Point, NC
6.4 HEMI
Deleting the grid heater and upgrading the intake horn will definitely assist airflow. Upgrading to a Fass or Air Dog fuel pump would be good options to add to the list.
What are your overall goals?
Greg
2012 | 2500 | CCSB | Custom MCC by Double R Diesel
A
Ausram
Cummins 6.7
Yeah thanks I have been looking at a airdog system as well. I want to get as much power as I can reliably without adversely effecting towing as I do a lot towing.
Power247
High Point, NC
6.4 HEMI
You need to beef up the trans before adding too much power. Revmax and Suncoast make some food stuff.
A
Ausram
Cummins 6.7
The tranny has been done because I blew it all ready
A
Ausram
Cummins 6.7
So what do you think would be best to do next?
Power247
High Point, NC
6.4 HEMI
I don't tow a lot but I do pull our camper several times a year. And it's a my daily driver so it has to stay reliable. Currently the truck is basically stock except for being deleted and tuned. Here's my build plan once I have money to do so...
Trans upgrades, RevMax since they are local
Fuel pump, I'm looking at the Fass 150.
Upgrade turbo with a 2nd gen style manifold.
Then maybe stock+ injectors when needed.
Greg
A
Ausram
Cummins 6.7
What tuner do you guys recommend? I have a XRT pro at the moment but would like something that can be changed on the fly
BWC
Northern CO
Cummins
I would say switch to efi live. Then 2nd gen mani with upgraded turbo.
Goodie1990
