2011 2500 285/55/r20 or 305/55r20
ltr450rider13
Looking for any info bout rubbing, fit of 285/55r20 or 305/55r20, +18 offset on stock susp, on 2011 ram 2500 ST. Pictures if you have. Wanna order monday so any help would be great.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Bud can't speak on a fourth gen but welcome to the site. We have alot of fourth gen guys on here that will be able to give you info.
ramhunter9
P-Star Jeep Wrangler
That set up should work out fine .. you have the right offset . Keep in mind our 2500's are about 3" taller than 1500's so we have more options to go higher .
Welcome to the Forum
ltr450rider13
ltr450rider13
Which?
Are the 305's to wide? The 285's are 32, 305's are 33, How much bigger you talking? How wide would you go??
ramhunter9
On a stock 2500 you can go 35x12.50 with no issues with that offset
jasonLmarsh
Dunno about the 4G ram, but here is my 3G Ram 1500 with 305/55/20 tires on 20x8.5 rims.
Dingo
jasonLmarsch, how far do those stick out on the side? is it hard to keep clean?? Thanks,
brandonschofield
ram big horn 2014
cummins 6.7l
2014 ram stock
I have a 2014 2500 ram with the black appearance group package, came with 20 inch rim (black). I'd like to put 305/50r20 tires on those rims, will they fit? Rubbing or problems? Thanks for your input!
