Shuddering and high frequency vibrations
tonys ram
I have a 2015 regular cab 4x4 with 12,000 miles...yes I baby it.
I have this issue of high frequency vibration that I can't pinpoint. Yes been thru the dealer since its still under warranty. I get the old run around. Started two star cases, also run around. Everyone says its normal. I say its not. Worse prior to shift points, but normally always there. When I take it out of MDS mode its half as bad. Is it the torque converter, is it the transmission, is it the motor, is it the MDS, ??? Or is it something completely different. I'm at wits end and want to figure this out once and for all.
Besides the high frequency, it shudders also.
Hope a Ram Care rep see this.
Thank You.
PCT
2019 2500 6.4
Northern California
Thank You.
There was another person on this forum that had this issues... Not sure what happened... I think he sold his truck, dealer never figured it out.
Sent from my SAMSUNG-SM-T817A using Tapatalk
Duffr
5.7L
Maybe driveshafts out of balance? IDK man.
I had some high frequency shuddering in a 2004 Cummins that couldn't be pinpointed either. They also told me it was normal. Long story short, it had a hairline crack on top of the transfer case that got worse and worse until it finally grenaded on me going 75 down the interstate. I was 200 miles past the 70,000 mile warranty when the t-case literally exploded underneath my truck. They wouldn't honor the warranty even though I had it in twice to be looked at by the dealer before it happened.
Just thought I'd share my experience with shuddering. Hope you get it figured out man.
PCT
2019 2500 6.4
Northern California
Ouch! Yeah I should have said check the drive shaft, they may force balance your tires (forget the name of it)
huntergreen
this issue was common in the 11 MY. there was a recall and chrysler was replacing transfer cases.
