temp display
nugget175
I have a 2000 ram sport 1500. The dome light area does not have the compass and temp display. Can I upgrade to one?
HKkid
Missouri
Not sure on the second gens. I know on the 3g you normally can, it will depend on if the wires are there or not.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
You will most likely need the sensor and stuff. I am not sure if the wiring is in the roof or not, but I believe there is a plug under the hood that you would plug the wiring from the sensor in.
willyjr
It takes quite a bit of work to install an EVIC. You'll need the correct sensors, and if you are using one with the MPG, service interval computer, etc, you'll need to access the PCM.
What I'm doing is installing a Gentex mirror w/ temp, compass, map lights, and is monochromatic.
ramhunter9
P-Star Jeep Wrangler
The mirror seems like a better idea and easier IMO
Kmiko
