Anyone with a 2" level on your 2nd gen?
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Looking to get myself a early Christmas present from HBS and curious if I need the swaybar drop brackets with a 2" level??
txbass06
NE Texas
5.9 Magnum
I don't have an HBS level but I don't have the drop brackets with mine and my end links are straight up and down
If nobody can give you a straight answer, try posting your question in their section and see if they're needed or just recommended
txbass06
NE Texas
5.9 Magnum
Nope lol. If you measure from the center of the hub to the bottom of the fender, the front end is an inch higher than the rear
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
would measuring from the ground to the bottom of the fender/wheel well (for rear) get the same idea!
bigbadram1500
Springfield, IL
That's how I measured mine while on level ground. I have a 2.5" readylift and my front is 1/4" lower than the rear.
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
I wouldn't mind that little of a rake I just want most of the damn rake gone lol
txbass06
NE Texas
5.9 Magnum
I was measuring from the ground lol. Just used the center of the hubs to make sure I was close to center of the fender lol
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I have a 2.5" on mine. I have a slight rake but not bad, maybe 1/2 inch or so difference. I will try and measure tomorrow
bigbadram1500
Springfield, IL
I didn't have trouble with my swaybar links and leveling kit until I had the links replaced. After that, they started breaking, so then I had to put the spacer in to drop the bar down.
Badger
Bettendorf, IA
I have the 2 inch. No problems so far. I bought the brackets just in case I needed them. Now they sit on the shelf. My endlinks aren't perfect but they are holding up.
txbass06
NE Texas
5.9 Magnum
Mine need replacing just from being 15 years old lol. I thought about getting the ones from HBS. They look pretty heavy duty and like they'd last longer than anything you'd get from a parts store
Badger
Bettendorf, IA
That's what I'm waiting for to put my brackets on. When mine fail I'm going HBS and getting a steering stabilizer then too. Make it one job
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Lol i gotcha now Mark. And Wendy, I wonder if yours being IFS has something to do with it.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I put Moog sway bar link on mine, still need to replace the other side sometime.
tjfbball01
5.9 V8 Magnum
leveling kit
i have an 01 ram 1500 5.9 2wd. I bought a 2" leveling kit from rough country and it looks so much better now. The leveling kit makes a big difference. I only have 245/75/16 on it but I'm getting 295/75/16. The leveling kit makes a big difference appearance wise. Defiantly get it!
Lemniscate_Mike
