I know this thread is old, but I just tuned up my hemi tonight and came accrossed this in my alldata program i use at my shop.
DESCRIPTION
The 5.7L engine (345 CID) eight-cylinder engine is a 90°V-Type lightweight, deep skirt cast iron block, aluminum heads, single cam, overhead valve engine with hydraulic roller tappets. The heads incorporate splayed valves with a hemispherical style combustion chamber and dual spark plugs. The cylinders are numbered from front to rear; 1, 3, 5, 7 on the left bank and 2, 4, 6, 8 on the right bank. The firing order is 1-8-4-3-6-5-7-2.
This is listed under engine description.
Now I ended up using autolite platnums. I dont plan on going longer on interval i did it because I dont normally use champions, but when I crossed the champion plug number on my napa direct sight it said that the autolites where the oe equivalent, and under the champions it said they wherent an exact oe designed match...so I went with the autolites. I use them more commonly any way so I didnt give it a thought until I got home and started reading some things...they where only like 50 cents more my cost so I dont mind about that, and it runs great. So Im gunna leave them in for now see what happens...
