I'm trying to diagnose an 04 Ram 1500 Hemi that all of a sudden would not crank. Friend had it towed home where I notice when turning the key to start, no sound(no solenoid click). Using wiring diagram, I had power up to the starter relay, but no ground. If I provide the ground and turn the key to start, it will crank. In looking at many wiring diagrams, I'm thinking the ground goes through the Transmission Range selector (45RFE trans) with switch inside the trans on valve body, but not sure since I don't have that wiring diagram, just Chiltons.
Other things I noticed (that the friend said happened at the same time):
1. Speedo and Tach sweep to full clockwise and stay there while key is on.
2. If I move gear shifter while stepping on brake with key on, there is no gear range indicator. Shows the P-R-N-D etc but no idication which position it's in. I verfied that the transmission lever is physically moving at the trans side.
3.When I hook up two code scanners to the OBD2 port, both come back after trying to negotiate the protocol that there is no communication with the vehicle. Verified there is gnd on pin 5 and +12 at pin 16 of the DLC.
4. I can hear the fuel pump and ASD relays cycling on-off-on-off as long as the key is turned on. Tried swapping relays(starter relay earlier, ASD and Fuel pump) with identical ones, same result. I see voltage fluctuate when the relays pick while they are cycling on and off.
5. Undid all the fuse box and PCM connectors to look for corrosion and loosened an re-tightened all the grounds that I could see in the engine compartment. Pulled each fuse out to visually inspect.
I'm tired and lost...any ideas?
thanks guys.
thanks guys.
