Loose Steering
HemiSport07
Central FL
OK I have a 2007 ram 1500 4x4 with 60k I just recently put a 2" leveling kit (bds) and a zone 3" body lift, got the truck aligned by the dealer and shortly after I noticed a slight loseness or slop from side to side wondering if anyone else has had this or how to fix it the passenger tie rod was just replaced before alignment and also do the make any kind of steering dampener system or a drop system for the sway bar not fond of the angle the leveling kit has it in
TheMaddog
DFW
Bump. Someone will chime in soon.
jbmobbs
murfreesboro, tennessee
yea i put a track bar drop on mine and a drop pitman arm on mine as well helped alot i bought them from skyjacker lifts
HemiSport07
HemiSport07
Central FL
I'm not sure if we have the same suspension if your talking about the truck from your sig but thanks
HemiBabe
DFW
Do you have the solid axle or IFS?
ADDCJ
cummins
have you checked the ball joints?
HemiSport07
HemiSport07
Central FL
Yea I think I have narrowed it down to rack and pinion would y'all recommended a mopar new or reman or a oreilly brand etc. Thanks
HemiSport07
HemiSport07
Central FL
Update on the problem I was determined to figure this thing out today well long story short I had a buddy help me put the zone 3" on and didn't think to check his work well there is a little cork screw that tightens up the billet spacer on to the rack and pinion shaft well it was left out put one in and the steering good as new just for reference if anyone has the same problem after bl install lol
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Glad you figured it out. Always gotta check everything! Haha.
AlljackedupRam
Central Florida
Come to think of it.. the guy that did that part of the lift is consider a "chosen"
one... mmmhhhmmm..... I think im seein smoke on this one. LOL.
rickof08
Kempner Texas
Cummins 6.7
I had the same problem when I did the zone BL. I tried so many different things until I realized I didnt put the set screw in. Its an easy thing to overlook.
Ed11
