DIY: Rear Seat Flip Down Mod
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
My JL 500/1 puts out slot of power and no over heating problems yet. And I've gone on 1 to 2 hr trips with constant playing.
Droid Incredible 2 on the move!!!
Zachohs
Archer City, TX
You know how there is that vent on the back wall what did y'all do to cover up that hole when you take the vent out to put the amp in?
thanks
Rusty1500
Michigan
I did this also one it was the most simple things i have ever tried but very cool thanks!
olbaid_83
Fort Worth, Texas
having an issue doing this....it seems that all 4 of the larger bolts holding the seats in are cross threaded the whole way in..... been at it for an hour and only have 1 out....any ideas to speed this up a bit?
NizZ8
V10
Did anyone do this mod on a 2nd gen?
Wish i found this before mounting my amps under the seats! :)
prican2000
Maryland
Magnum 4.7
Subscribed!!!!!!!
Gonna instal an Amp on that back wall this week for my Passenger Underseat enclosure!!!
This Forum is Great - Thanks for Sharing
RubberFrog
RubberFrog
I've been rocking the **** out of that amp for two years now. No over heating.
JonBoy
2002 quadcab 1500
Wish you could do this for the 4th gens.
Before the ram, I had a silverado, the chevys have welded hooks too, the mod I did on that truck required that 1/2" be cut off of the hooks coming off the back of the seat, this allows the seat to lift free in the same way. There is a risk of taking too much off of the hooks, but if you are careful and the setup is the same, Its probably doable
jsmith180601
I just did this mod and its Sooo easy...
Planning on making so I can drop the rear seat down and my shotgun will be right there. A place to have it close but out of sight
Sent from my HTC One VX using Tapatalk 2
keonos
Does this mod work on 2013 Crewcab?
Omicron
USA
Subscribed. I'm going to figure out a way to make this work in my 4th gen, whether it means cutting the welded hooks off and re-welding them on upside down, or bending them, or notching them, etc.
man n black
Cummins
Subscribed
@ Omicron. ....Please post your resolution in this thread or a link to the DIY you're gonna write ;-)
Ch
Sent from my SM-N900V using Tapatalk
Omicron
USA
Took a look at it tonight without removing the rear seat, and believe I have it all figured out. Be later this week before I can take it apart and confirm my theory. Stay tuned. :)
