How much of a drop would i get if....
truckin151
2013 sport
I were to add some 2" drop shackles, remove the OL springs, and cut the first ring off of the front coils?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I would say 2-3" on rear, drop shackle will give you 1.5", and then the overload would go even further.
BlackedOutHemi
DFW, Texas
2012 & 2012
Really? I've always heard the 2" drop shackles were 1.5". Well then, okay!
Trupiano
Registered User
6.7L CTD
I'm sure it's not an exact science. Mine was a 4x4 quad cab, while Truckin's is a 2x4 single cab. So I could be off a little. Have to see what Kristin says about her's I guess lol.
HemiBabe
DFW
lol, well, I still have the OL springs on, but I've always heard they only drop it an extra 1/2". I have a pic with the 2" drop shackles, honestly, I could barely tell they even dropped it at all. So prolly an overall of maybe 2" total drop in the back?
It would prolly level it out some, but I noticed the massive leveling with my 2/4.5.
My truck still has a little bit of a rake to it.
Here it is:
2" drop shackles
2/4.5
T
truckin151
2013 sport
Not trying to level it, still want the raked look
HemiBabe
DFW
oh, ok... well i think what you originally stated would look good
T
truckin151
2013 sport
I just don't want it to be to extreme of a drop up front. Basically want it to drop as it sits now straight down. So if goes a full 2" in the rear I'd want the front to drop about an inch to keep the raked look.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Sounds like your org thought would work good. Lower to the ground, less wind res.
HemiBabe
DFW
I think if I remember right, from what I've heard the OL springs give you 0.5" drop, that would be a good combo with the look you're going for
T
truckin151
2013 sport
Well ordered the drop shackles, should be here Wednesday. Installing them Sunday. Also orderedsomething else to give the fronted some pop.
S2kiHemi
Houston TX
When I installed drop shackles and removed the o/l leaf on my 05 the back sat slightly lower than the front. Maybe a half inch or so. I did have SRT calipers/spindles so that raised my front slightly.
T
truckin151
2013 sport
Good to know, I am going to cut a ring or half a ring out of the coild as well to drop the nose a bit more to keep the raked look at the same time
05singlecabHEMI
Lilburn,GA
i keep running into the decision, lift the front tolevel it completly, or lower the rear.. ill have to see how yours turns out.
i got some goodies coming from 3rd strike this week also.
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
I would say 2.2.5 in the rear. Visually i could not tell much difference in mine but it was very noticeable when going in and out of the bed. Went 4/6 2-3 years later.
mikes04hemi
Florida
Make sure you take some pics! :) Curious to see how cutting of the front coils go and ride quality.
Good luck bud!
No members online now.
alphaprojects
