Installed JBA Headers today
Longhorn2011
Sugar Hill, GA
Installed my JBA Headers today. Jacked up the front and put it on jack stands. Removed front wheels and wheel well liners and unbolted the steering shaft. I did most of the install sitting on a stool. It took about 4 1/2 hrs by myself. Knowing which tools I need and what to do I think I could do it in 2 hrs now. I had to bend the dipstick tube a little to reinstall it and keep it from touching the header. On the passenger side install the gasket with the top second bolt from the rear (if you don't you will cross thread it, trust me on this. Luckily I was able tap the threads). The header flange is slotted so you can slip the header onto the bolt then you can install another bolt to help hold the header. It would help to have another person helping. The drivers side flange is slotted for all the lower bolts so you can install the gasket and lower bolts and slip the header onto the lower bolts. I didn't use any of the mounting hardware that came with the headers. I used Stage 8 Header Bolts and factory manifold gaskets. There were supposed to be some stand-offs to raise the heater hoses up a little further from the header but they were not in the box so I'll have to contact JBA, but I don't think they are really needed. I didn't disconnect the y-pipe since I don't have one as I have true duels. I just unbolted the exhaust from the manifold and pushed the exhaust back as far as I could and it was fine since I installed the headers from the fender well. Tomorrow I have to go to the muffler shop and have them fix the leaks they left when they installed 2 Aero Turbine AT2525 mufflers and I think I'll have them install an x-pipe. Then I need to try out my new HD GoPro Hero. Also I think I expanded my vocabulary today.:evillol:
S2kiHemi
Houston TX
Very nice! We need some vids of the exhaust now.
05singlecabHEMI
Lilburn,GA
there is not a video to prove your work. thus i do not believe it! LOL jk.
very good work dude. i bet with the true duals it sound awesome!
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Very Nice Man. They Look Similar to my ******/Flow-techs.
Happen to have a set of BBK's sitting in the spare room for the Magnum, can't wait!
the codes
Houston, Tx
Magnum 5.2
very nice work bud
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Danny I was thinking the same thing about the Flow-tecs, just the way the front pipes come in.
09SMOKINHEMI
TEXAS
very nice man.... have you noticed any gains?
Longhorn2011
Longhorn2011
Sugar Hill, GA
Throttle response is a little better and power seems to be more linear. I just got back from the muffler shop and I still have a leak at one of the mufflers, I guess I'll have to weld it myself.:mad:
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
That sucks they cant get your leaks straight.
Picton
Houston, Texas
2015 - 1500 Express CC 4x2
Awesome...you should like them...I like mine!
ADDCJ
cummins
did it make the truck alot louder?
Picton
Houston, Texas
It definitely added some depth to the overall tone for me...but his setup is different. He went with 2 SI/SO mufflers where as I have 1 DI/DO.
