recovery point on factory hitch?
Ramsrule123
I may need to pull someone out one day. is there a point to do so on the factory hitch? or is the front tow hooks my only option? i really don't like to pull people out in reverse. any thought? thanks
Stangshcky12
Oshkosh, WI
5.9 Cummins
Get a d ring reciever
You have to be careful pulling people out from the front or back. It's very plausible to tweak you frame when doing so.
Ramsrule123
Ramsrule123
thanks that's what i was leaning to. not going into the recovery business, just like to be prepared.
Sharp Charge
Brunswick Oh.
You can also use the hitch pin with the recovery strap looped through it.
Like this:
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I have the D ring receiver it is sweet but what I used to do before I had it was just rap tow rope around tow ball and down under where ball tightens and it is nearly unbreakable.
$miley
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
A rated draw bar with a rated D ring with a good snatch strap for a weight you feel good about pulling.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Like this:
That's what I do. Have some good straps too. Don't use chain!!!!!! Ask my tailgate. Lol
Sent from my apple torching Droid.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I use this.
$miley
Red 2012 Crew
Central Illinois
I just use my regular hitch and put a clevis with a hitch pin through the ball mount hole. You won't tear it up.
Reticle918
