I have grease fittings on my front suspension?
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I thought these trucks had sealed systems? I was under my truck putting some grease in my Universal joints and thought I would just check upfront to see if there was anywhere that I could add some grease and to my surprise I found some fittings on the suspension up there. Is that normal for 2002? only reason I ask is I noticed that my front shocks are Sensa-track and not OEM so I was thinking that maybe whoever owned before me changed the components of the front suspension to ones that had fittings. What's strange to me is that I only find one on the left lower side and none on the right side at all. I'll post a picture .
Any thoughts on this?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Those lower Ball joints don't nor mally have a fitting, even the after markets however not unusuall. I have one upper that has a nipple out of 2 and both tie-rods as they have been replaced along the way. Shocks require changing every 48 K miles by the book so that would be normal too.
02blkram47
02blkram47
Lebanon, NH
wouldn't you think that if one side was replaced that they would have done the other side as well? isn't that common to replace both sides even if you only really need to do one side? I would have thought that I would see a grease fitting on both sides
Lyndo
those must be aftermarket, i IIRC it's moog that makes greasable ball joints?
Stangshcky12
Oshkosh, WI
5.9 Cummins
There's several companies that make greaseable, moog are pretty much top of the line though
People are wierd/stupid which is why you have to be really careful buying any used vehicle
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Was looking at mine 2 weeks ago and IMO Its seems to be a fairly big job to replace the lower ball joint on a 3rd gen 1500 4x4. I have some side to side movement on passenger side but no up and down (Original part). So I plan to replace just the one side. The other appears to have been replaced by 1st owner and does not have a nipple. There is not much clearance between the control arm and Knuckle (maybe why) and it looks like the new balljoint will require to be pressed in on a press so its got to come off.
I do agree that Tie-rods should be changed in pairs as an alignement is needed.
Oefootball_70
OLATHE
I have just one side tire rod replaced with a greesable. the other side is factory sealed.
HemiBabe
DFW
Dang you got lucky lol someone did the work for ya haha
[tapatalkin]
Bettula
