DIY: How to make the cigarette lighter work 24/7???
LustinJam
HEMI
Is there a way to convert the cigarette lighters to function ALL the time??
Having your cigarette lighter functional even when its off and locked up is so under rated. Hell of a perk to be able to charge up your phone while you're not in your car...
quietpeen
2021 TRX
Hellcat
i would think all you would have to do it tap into a constant 12v else where and connect it to the lighter.
Nickxxxr
Near Reading, PA
Just run the wires to positive and negative of battery. Cake work and it'll be on 24/7
Sent from my SAMSUNG-SGH-I897 using Xparent Green Tapatalk
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
If you have center console the one that is in armrest is always hot already at least on my 09
$miley
Stangshcky12
Oshkosh, WI
5.9 Cummins
One of the lighters is always on and one turns off with the ignition which is nice when you have a cb or a scanner
I have my air horns to the one on the ignition as well so people can't use them excessively
suzukiquadrider
cummins 5.9, 6.6 duramax
I had that in my old Chevrolet. the battery died on more than 1 occasion because of things that got left plugged in.
L
LustinJam
HEMI
Didn't check the plug in the center console, that'd be nice to have 1 that was and 1 that wasn't.
Good lookin out fellas!
L
LustinJam
HEMI
Yup, the center console does the trick & keeps the phone out of view...
GoinDownhole
Midland, Tx
the passenger side plug on mine is always hot, and the drivers side is switched via ignition.
I've got the fold down cupholder arrangement, no console.
cmccarthy
Sorry to resurrect this old thread, but I ran across it while searching for something else and I figured I'd add a tidbit of useful info for the next guy.
The cigarette lighter with a picture of a battery on its little flip open cover is hot all the time, and the one with a picture of a key on it is hot only when the ignition is on. It's like this on all 2011 and newer mopars, and might be on the older ones but I can't say for sure.
