t-stat broke?
the codes
Houston, Tx
Magnum 5.2
okay so this is my trucks temp gauge after about a hour drive in about 50-60 degree weather driving about 70 with a few passes at about 80-85. is my t-stat broke or is my engine just running pretty cool? it barely ever gets about that line it's almost resting on.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
It seems your t stat is stuck open. They don't have a t stat that low. And for good reason. I'd change it. Or maybe it's the sensor itself? Idk.
the codes
the codes
Houston, Tx
Magnum 5.2
should I just go ahead and replace it? I mean it's the stock one, almost 160,000 miles. might run to autozone and pickup a replacement.
BlackedOutHemi
DFW, Texas
2012 & 2012
Yeah. Might as well go ahead and replace it. They're not expensive.
the codes
the codes
Houston, Tx
Magnum 5.2
prob good idea
the codes
the codes
Houston, Tx
Magnum 5.2
