hemi engine spark plug question??? aviation related
joeg45
Katy, Tx
ok so i have a question if anyone on here has ever worked on a reciprocating aircraft engine (say like a piper warrior)? ok so im going to a school to become a licensed A&P mechanic and we were talking about spark plugs when we were troubleshooting a engine yes i know airplanes and vehicles are different in many ways but they are similar as well so basically the engine i was working on has dual spark plugs (2 per cylinder) yes it is a horizontally apposed engine and i know the engines in my truck is a "v" type engine
but this is were my question comes in the bottom spark plugs are the ones that get fouled out quicker than the top ones on a horizontally opposed engine do to oil settling when the engine is off so what we do is take them out clean them (spark plug abrasive blaster) and switch the bottom plugs and the top plugs in firing order of the cylinders to help balance out the wear so they last longer can this be done on our engines as well to help keep the spark plugs lasting longer
Stangshcky12
Oshkosh, WI
5.9 Cummins
Could be done? Yes
Is it worth it? I wouldnt think so. Guys do do it though.
You hit the nail on the head when you mentioned the difference in the block design. Your hemi should not see nearly the amount of oil in the cylinder that an aviation engine does. This is also a reason (among others) that people install catch cans in the new hemis
Trupiano
Registered User
6.7L CTD
Plus, that would be a major ***** to preform on a regular basis. I've never had a spark plug foul, so in my 04 3.7, 05 5.7, or so far in this truck. So I would just recommend the usually scheduled maintenance.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
My first set were way past due when I changed them, running 93 all the time they were not bad at all, was kinda suprised since they were the OEM coppers.
tmerritt530
287 ci
It also costs a lot more to have aircraft engines serviced. I would not bother doing this on automotive engines
joeg45
joeg45
Katy, Tx
So sounds like its just better to follow the regular maintence idk it was just one of those things tht hmmm I wonder if this could be done with my truck especially if I go with a better spark plugs when I change them just to help them last longer
quietpeen
2021 TRX
Hellcat
def. sounds like way to much work, and like others have said, no fouling issues and people have run the stock copper plus well passed the recommended 30,000 miles
Stangshcky12
Oshkosh, WI
5.9 Cummins
I've never really done research on it but I have seen alot of people say that the regular plugs burn better then the "platinum" plugs do
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Bingo! i wouldn't listen and waisted 200 on iridiums that looked horrible after one Year, Back to Coppers now in both my engines.
joeg45
joeg45
Katy, Tx
So has anyone tried the E3 I think it is the one that are supposed to give you more horsepower
