Radiator overflow leak
RompinRam
Hoffman Estates, IL
4.7 Magnum
Hey guys, for a while now my overflow box has been slowly going down. I cannot find a leak and neither can my mechanic. 03 4.7L. Jus wondering if anyone has had or heard of anything like this happening before. Or if there are things I can check. The oil is fine. Had it change and have checked it. Other then that I don't know what to look for.
Tapatalk'in
Deviate
St. Augustine, FL
2005 4x2
How slowly are we talking? Do you ever see any kind indication of a leak like a small almost dry spot on the driveway or anything? Mine did this for quite a while until it gradually got worse, and it was the water pump slowly leaking. At first it was so slow that any spot on the driveway was drying up before I could spot it. But eventually it got to the point where I could see a small trickle from the water pump itself.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
My overflow tank itselft will weep at the seam.
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
Really slow leak. Still have yet to ever see a wet spot on the driveway. Don't really have to fill it up too often.
Tapatalk'in
GhostRam94
Hunstville, Texas
2009 Laramie CC
ive had my radiator replaced twice because i noticed at the very bottom on the driver side there was a very small leak, thank god for warranties and i replaced the overflow bottle and cap because i thought it was that but i was wrong but i guess now i dont have to worry about it anymore. hope you find your leak. i would look at the bottom driver side because thats where mine has been the last 2 times.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Pop the hood and check the top seam on the tank to see if its even alill shiny. Mine will lose just alill (less then a cup) over about a 3-4 month time.
LB3711
Trumbull, CT
3.6L V6
Do a pressure test. Also you might be burning it.
Sent from my tapatalk equipped AT&T iPhone 4.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Ghost yeah there were a few bad batches of rads that went out. Mine split on the side one day after I got to work thankfuly.
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
I will check under the driver side and also the top of the tank and get back to you guys..
Thanks
BKNBK
MT. Vernon, IL
Mine had a very small crack at the top corner of the drivers side. The plastic caps are known to leak. A new radiator is only $100 or so.
noraa73
