Synthetic Oil
sinisterc6
Are there any reasons why synthetic could not be used in the 5.7 hemi?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
I use it in my Magnum RT with a Mobil-1 Filter and I plan to go 4-6 Months (No more Warranty-Yes!). I only drive her 6-7 Months a year. Just started using it at 30K Miles before I parked it. Some will argue and recommend that the Motor should have some Miles on it first before switching from Conventional. But there must be plenty of fourth gens out there that have run it since new like Kevin without any reported problems.
My Ram is too old for that kind of a blood transfusion so I stick with Castrol High Mileage and a Mopar Filter.
scoose
Atlanta
2007 1500 sold, 2011 1500 5.7 sport sold, 2016 6.7 2500 4x4 sold, 2014 2500 5.7
The 07 I sold this year got nothing but Mobil1 Synthetic for the 58k miles I owned it and the 2011 gets nothing but Mobil1 Synthetic. Never had a problem
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
No there is no reason not to. IMO all vehicles can benefit from Synthetic and by not running it you are missing out.
Chrysler recommends 8000k on an oil change using Dyno oil imagine what you can do with synthetic and a really good filter. I do 10k oil changes now and I am not afraid.
Picton
Houston, Texas
2015 - 1500 Express CC 4x2
I heard that once you go synthetic, you can't go back...I mean that literally as I heard that from a mechanic. Is that true? If so, why couldn't you switch back to conventional again?
txbass06
NE Texas
5.9 Magnum
I've never heard you couldn't switch back to conventional. Just that if you switch to synthetic on older motors, it can cause small leaks where there weren't before
BlkPearlSport11'
Cresson,Tx
2011 Black Sport Quad Cab 4X4
No sir nothing but Royal Purple 5w20 with a K&N oil filter for my truck! I like the good stuff for the hem dog lol.
Grubrunner
I changed my oil when I drove the truck home with 17miles on the clock.
Nothing but Amsoil and Wixx filters on all our vehicles.
JET
Arlington,Texas
1996/2011 Ram 1500 Sport
5.9 Magnum/Hemi 5.7
Changed mine after 500 miles and used Royal Purple 5w-20 and runs like Ram.:birgits_tiredcoffee
Bikenut
Orange Count, CA.
Changed mine at 1500 with Valvoline 5-20 and a Bosch filter. I'll run Full Syn. for the life of the beast
jgos929
Changed mine at 550 miles with Pennzoil Platinum 5w20 and a Bosch filter.
It helped with the HEMI tick big time.
Burla
2010 Hemi Reg Cab 4x4
synthetic oil info
ANYONE WANT TO KNOW ABOUT OIL READ THE ABOVE LINK!!
If Amsoil is telling you Mobil One is true synthetic, then you better believe it is, lol. Most high quality synthetics you gonna to have to buy online, they are too expensive for stores to carry. Not enough people understand how much better they are to use in your car or truck.
There is no reason not to use synthetic, unless you change your oil every 6 months without putting many miles on it, then it may not be worth the extra dollars. However, you need to make sure you are using true synthetic group III oil, like Mobil One. The rules are relaxed for group three so many oil companies filter out sulfur and call it group III and they legally can. The carbon molecules in these cheaper oils are not uniformed meaning they will cause more friction then smaller carbon molecules group III oil. There other oils that are more expensive but the difference is negligible from a high quality group III oil.
People with the Cummins should really consider getting a bypass filter and running one of these oils, but for us gas engine guys just mobil one is all your gonna need to use. The reason the Cummins guys should get the best oil is because with a bypass filter on they can get 100,000 miles or more with a single oil change. I've read up extensively on this at Bobistheoilguy.com and TDR. If I didn't sell my Cummins I would have put a bypass filter on it. I bought it and then my knee gave out from all the shifting, getting old SUX! Had to sell it 6 months after I drove it off the showroom floor, but the good news was I sold it for 500 bucks more then I paid for it :)
_____________________________________________________________
What about synthetic motor oils? Do they need Viscosity Additives?
Group IV (4) and Group V (5) base oil (synthetics) are chemically made from uniform molecules with no paraffin and don't need Viscosity Additives. However, in recent years Group III (3) based oils have been labeled "synthetic" through a legal loophole. These are petroleum based Group II (2) oils that have had the sulfur refined out making them more pure and longer lasting. Group III (3) "synthetic" motor oils must employ Viscosity Additives being petroleum based.
Group V (5) based synthetics are usually not compatible with petroleum or petroleum fuels and have poor seal swell. These are used for air compressors, hydraulics, etc. It's the Group IV (4) PAO based synthetics that make the best motor oils. They are compatible with petroleum based oils and fuels plus they have better seal swell than petroleum. Typically PAO based motor oils use no Viscosity Additives yet pass the multi-grade viscosity requirements as a straight weight! This makes them ideal under a greater temperature range. One advantage of not having to employ Viscosity Improving additives is having a more pure undiluted lubricant that can be loaded with more longevity and performance additives to keep the oil cleaner longer with better mileage/horsepower.
How do I know what motor oil is a Group IV (4) based PAO synthetic motor oil?
As more and more large oil companies switched their "synthetic" motor oils to the less expensive/more profitable Group III (3) base stocks it has become much easier to identify which are PAO based true synthetic. Of the large oil companies, only Mobil 1, as of this writing (12-15-2007), is still a PAO based true synthetic. The rest, including Castrol Syntec, have switched to the cheaper/more profitable Group III (3) petroleum based "synthetic" motor oil
_______________________________________________________________
Grubrunner
The words "Mobil 1" and "synthetic" contradict each other so, therfore, should never be used together in the same sentence..... without a period seperating the two.
Hope this helps.
Burla
Grubrunner why not contribute more to the knowledge base then that, perhaps proof or something else along that nature. Amsoil was stating that Mobil 1 was a high quality synthetic, and that is their competitor, lol. I could care less about one company or another, but I would at least like to hear other options for a high quality synthetic oil. If for some reason you don't think Mobil 1 is high quality synthetic then what is? The oil guys at BITOG favorite oil is Penzoil, and Mobil 1 is second.
2ramsinaweek
Hope this helps.
The Mobil 1 5-20 I just bought says synthetic right on the bottle. For what I paid for each quart, it better be.
dmclone
Iowa
In the past 15 cars I just use what the manufacture recommends. I figure they know a lot more about the engine then I do. All the turbo cars I've owned have used synthetic. My wifes 2013 Acura RDX requires synthetic but only requires an oil change about every 10k miles so I don't have a problem with it. Just my opinion here but I have heard of people using synthetic and still changing it every 3k miles. I think that's over-kill for about 99.8% of the population.
I feel the same way about gas. My Infiniti said that 91 octane was minimum so that's what I used. The ram says 87 so I see no use in paying 30 cents more per gallon.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I agree with you except Ram recommends 89 for HEMI I want to make sure no one is confused by that. It can run on 87 but performance may be changed.
$miley
dmclone
Iowa
$miley
Good call. I assume 89 E10 is fine?
bmireault1980
