I don't know anyone that has a 2016 yet, when the weather turns to spring, I'll head to a dealership and test the 2016s to see if there is a change.
Thanks - is a static voltmeter test adequate? I can hit up a dealer here who has a few 16's with the factory controller - the weather is fine. truck running, squeeze the manual control to max - should see ~~12+v on the brake pin to ground?
Guess I also have to stick my head under the dash to find the part number...
Or even make a compatible controller that fits in the center stack where the OEM goes. That would be sweet, may be a letter to Tekonsha would make it happen.
Yeah - with the lack of extra leg room, and the increase in "integrated" controllers, seems like Tekonsha should add a modular to it's lineup - add the factory-location control (and/or display), and hide the more universal module away under the dash. Add a (few) generic display/control's to the lineup for alternative integration.... But more expense on their end to build more and more physical interfaces. :/
Of course, optionally being able to add more truck integration - ie brake pedal pressure - could go a long way. Did see someone with an obd2 interface - but those suck due to plug placement...
Ah well, ordered another p2 since I can't remember since it since I sold my second gen, maybe I let it go with it. I'll need it for another project truck in the future, and it'll get me by until we can confirm the factory module works right!
thanks.
..david
