RodRam
First the 1223v is good bit stiffer than than the OEM springs that is why I feel most of the bumps the diameter of the coil's is much larger and they did not compress more than a 1/4 " when lowered off the jack also my OEM springs are variable rate they look identical to the 12 23v springs and have 4 tight coils at the top and the rest wider spaced to the bottom and look exactly the same except for the spring diameter being smaller not sure if all 2015 cc have them but mine does and on my build sheet it lists a option # and the words " raised ride height "
