drittal
https://www.google.com/url?sa=t&sou...7Qnhb1oN1FRDoRu7w&sig2=xFiPKW8cewAtQUZ71nxK1A
Sent from my SM-N900V using Tapatalk
I don't tow at 72 either, but my 6sp 6.4l runs at lower rpm with 6th locked out in tow haul.
Mpg For Speed - Fuel Efficiency Vs. Speed
Thanks. What's a good rpm towards for? Should I not use the cruise control... I think my rpms are around 3
I'm not sure how your 8sp works with tow haul. The 6sp in my 2500 doesn't let me into 6th when I have T/H engaged. Maybe I don't tow fast enough for it to let it shift into 6th when towing.How and which gear should I lock out on my 8 speed? What's the purpose of locking out gear...??
Depends on the terrain, Load and minimum speed of the roadway.
Really is a common sense thing. go faster, downhill. Keep RPm as close to 2K, as ou can, goign uphill until you need more rpm to top the hill. wait until the very last poossible moment to put yoru foot iinto the pedal.
i cannot drive that way. gas is cheap. I only have so many minutes on this planet. not oging to waste a single one trying to save a few pennies on fuel, if i wanted cheap fuel burning car, wold a got a 3cyl import POS.
I believe locking out OD it is to ensure the transmission is being properly oiled when towing. If not, excess heat and wear can/will happen.
Do a quick search for tow haul here and see what pops up.
Might want to look at the specs on your trailer tires. Many are only rated at 65mph Max.
An 8-speed with 3.21 gears at 70 mph will be about 3050 in 5th gear. If you can get it to stay in 6th gear, it will be just under 2400 rpm and should help gas mileage and still have enough torque for flat steady speed. But to get that, you likely will need to turn off cruise control with the trailer. Otherwise it will downshift to 5th too often with a slight incline or wind gust. And the computer will hold 5th gear a long time. Try getting up to speed normally (maybe 1 mph over target), then using the gear +/- buttons on the steering wheel, select 6. You may have to ease off the throttle slightly until the computer shifts to 6th (2400 rpm at 70 mph). If you see a slight incline coming, accelerate slowly (avoid downshift) a couple mph and then hold throttle on the incline allowing the mph to drop. If it drops too much (>5 mph under target), you might decide to apply throttle to regain speed and start all over again on the next flat section.Good to know. I'm not 100% sure it was at 3k just going off memory. I have the 8 speed with the 3:21 gears. Same here I do the speed limit not over. Usually if the speed limit is 75 I will do 70-72 if it's not windy.
Without towing mine was up there about 20 mpg at 75 mph
Ah so, Daniel-san.Speed hurts mileage. The more I go above 60 the quicker the gauge drops. My 3400# 17.5 footer (2900# before wife's extensive packing) nets me around 12.9-13.0 at 65. If I back off the throttle, 13.5-14 is easy to do. Also I use the WW ll Japanese trick of applying lots of wax. (They waxed the wings and bodies of the *** Zero's in the war.) Less drag really helps. Bet I get 1/2 mpg boost at 65 if I wax the trailer.
lol thanks i know what you mean i don't like to go any slower than i have to... i don't speed with a trailer though...
i will just have keep cruise control off and watch the rams. i like to go about 70 if the speed limit is 75 mph... i have noticed it works a lot harder keeping 75 mpg.
Never use cruise control, unless totally Dry, even, Flat roadway. Also, never use cruise in snow or rain. too easy to loose control if one tire spins out.
Cruise, by definition, will attempt to maintain a speed. doing so, for tiny micro adjustments, to compensate for all the infinitesimal grade breaks, will kill fuel mileage.
Example, look at teh road, any road, it will hardly ever go more than 500-1000ft without some osrt of grade change, the longer your rig,, the more that tiny little grade change will affect your speed. Cruise will raise teh rpm's to re-attain that speed.
WHen YOU are in control of the RPM's, you can choose to allow the tow vehicle to slow, over undulating territory, knowing that once you get over teh slight crest, the sags is where you will re-attain your speed. Cruise control does nto know this.
Also, when climbing a substantial hill, you can choose to allow speed to be reduced, even by 10 MPH speed reduction, if doing so will get you that much closer to the actual top of the hill, so that a tiny 300-500rpm increase will allow your Rig to actually "Crest" the hill.
Where upon you can instantly reduce your RPM's, so that the downhill run will allow you to re-attain your speed, even picking up some. Cruise will limit all gains to teh whatever speed the cruise is set, you cannot gain an extra 3-5mph cushion, for the next hill.
Again, this is not complicated, don;t make it so, use your head and common sense.
EDIT:
By the way, with 3:21, it takes you much more RPM to get that load moving, from a dead stop. Also, takes much more RPM to get it accelerating, from low speeds, to higher ones. Take your time, use the lay of the land. Once you are actually AT your preferred highway speed, though, that 3:21 will really shine. Just realize you have traded higher gearing, for better mileage once desired speed is attained, at the expense of acceleration, at any speed. With 3:21's, it is the acceleration, and resulting RPM increases, which are killing your Mileage. With my 3:92's, it;s the consistently higher RPM's, once my cruising speed has been achieved, that kills my mileage.
I am pulling a 25 foot camper used for work.about 6500 pounds..: Lots of highway miles. Approx 25,000 miles a year highways.
I have a 1500 quad cab 5.7 hemi with 6,4 bed. 4x4.
I have been towing with tow haul mode always on. I use cruise control between 68-72 most of the time depending on wind etc... So far I'm averaging like 7-8.. Maybe one trip managed about 9 mpg...
Is anyone else getting better mileage..?
