Moparkid
- May 25, 2014
- 4
- 0
- 1987
- La small block 318
alright, having made major progress on the replacement of the fuel system on my truck, i think its time to start a discussion on something every young adult wants: performance. i have a few questions regarding the engine trans and rear axle on my truck, so lets get started.
the trans- my 87 w100 power ram is equipped with an automatic trans, no overdrive. can this trans handle an increase in horsepower/torque, and can it handle light towing (one vehicle on a trailer, or pulling someone out of a ditch)
the engine- what are some popular cams for this engine? im looking for maximum torque, its a truck after all. also, should i upgrade the entire valvetrain, and heads, or am i OK sticking to just a new cam?
with heads, if i were to install 340 or 360 heads, what sort of modifications are required, and what modifications are recommended?
now one thing i was interested in doing was converting to efi, which edlebrock has kits for. is this worth the money, will it help the performance or reliability, or is this just a great way for me to waste a good chunk of money making my vehicle worse? it currently has a holly carb, i believe 600 or 650 cfm (need to check, been to busy on getting the truck road worthy to look at performance parts). i have been told 600-650 cfms is the most i should really go on the 318 la, is this accurate?
headers/exhaust. i have been told to just replace the rusted bits of the exhaust and be done with it, but id like to install a performance exhaust system. is this worth the money, and are the kits available from such sources as summit racing actually compatible, or am i going to need to do modifications to the exhaust, engine or truck to get the system to fit properly?
now with the axle, i know i want a locker or a limited slip for both axles. i have found plenty for the dana 44 that sits up front, but not for the 9.25" rear end. is it worth trying to find an lsd for this axle, and if so what companies should i check out? or am i better off looking for a new axle?
at this point im trying NOT to waste all of my money on this truck, its high miles and i bought it cheap, id like to keep it cheap so i can abuse it as a work and play truck, until i have the finances to further upgrade the vehicle, or replace it. thanks in advance for any advice you may give- Alex
