2015 2500 suspension noise
Phil21502
Frostburg, MD
Anyone else have a noisy suspension on these trucks? It definitely is coming from the rear. Sounds like a kreaking noise. It's driving me crazy.
zeddy
Burbank, Ca
My 2015's rear radius arms creaked, especially if i walked or jumped in the bed . I sprayed lubricant on the radius arms joints and it went away.
Ratket
Arizona-
The rear brake line can rub on the bracket and cause noise as well
NewBlackDak
Hemi 6.4L
…and this is a terrible noise.
Ratket
Arizona-
Just leant my truck to my brother lol-
It's one of the rear brackets before the axle
Mountaineer83
Charleston, WV
I had a creak, but it wasn't the suspension. It was my spare rubbing on the heat shield actually, but I only heard it when I went over a rough section of road or across railroad tracks. I found out by climbing under the truck and shaking the spare, it was definitely the creak I was hearing. Just a thought!
regularcab2500
Buffalo
5.9 Magnum
I had creaks in my 2014 as well but spraying the suspension joints with lithium grease always solved it but only temporarily. Getting your truck undercoated helps this too and lasts longer than the lithium grease but unless you live somewhere where salt is an issue, its not worth the expense.
dbrock34
I've noticed mine doing this recently as well now that it's warm enough to roll the windows down. Guess I'll be stocking up on lube!
Phil21502
Phil21502
Frostburg, MD
Mine is definitely the rear ebrake cables rubbing the bracket. I might just remove the bracket all together
Buckfat
SW FL
I had the same brake line squeak. The metal loop that is on the side of the frame. Bent it with my hands ,squeak gone.
PatinAZ
Haven't noticed on mine. I always use Chemical Guys Bare Bones on frame/suspension/axles to keep them "conditioned" and new looking.
Goodie1990
