2016 PowerWagon Stock Wheels 37's What Is Needed
WilliamS
Tampa FL
Pretty simple, my father wants 37's on his power wagon. Likes the stock wheels but wants to know the least needed to cram 37's under it. He doesnt rock crawl or hit the bogs, just wants to fill out that wheel well. He has G2 35's and they just look too small for his liking.
Blue Streak
Southern Oregon
2017 POWER WAGON & 1979 W150
6.4L HEMI & 440 Wedge
The best way I have seen is Thuren's leveling kit. It's not the cheapest but it does it right! It's listed for $740 on their web page.
DannyMK2
Long Island, NY
2015 Power Wagon
im pretty sure you can fit a 37x12.5 on stock wheels on a completely stock wagon. id probably do a level to avoid the stuffed look though.
W
WilliamS
Tampa FL
Hes going for the stuffed look. 750 for a level is absurd, trying to see what others have done and what cutting is needed.
reloaderguy
Oregon
2016 Power Wagon
He doesn't need a lift. They'll fit but he needs to trim plastic and the pinch welds. The tires will be hard into radius arms, I'd recommend 1" wheel spacers. I opted for aftermarket wheels.
MADDOG
Out Exploring Arizona
2.5" spacer level runs about $500, give or take $50, in my area using a Tuff Country 32909 kit with the shock relocation bracket.
37's on stock wheels would need some spacers to clear the suspension up to full steering lock.
I also opted for aftermarket wheels with a +18mm offset so I didn't need spacers. I'm not sure what the stock PW wheel offset is but the difference between that and a +12mm offset should be sufficient for spacers.
W
WilliamS
Tampa FL
That kits says its not compatible with the power wagon?
reloaderguy
Oregon
2016 Power Wagon
The PW will fit 37's without the lift. Truxx is the only company making a PW specific leveling spacer.
The OE PW wheels have 57mm of offset.
W
WilliamS
Tampa FL
YqSVwU6
Power Wagon with 37's, no lift.
What all needed to trim out, as well any change to back spacing?
reloaderguy
Oregon
2016 Power Wagon
You need to trim the hump at the bottom of the fender flair, the plastic tunnel in the fender liner over the pinch weld, and about 3" of the pinch weld. I used a dremel on the fender liners and flares and an angle die grinder for the pinch weld. I also pulled back the fender liner and zip tied it to the front body mount (drill two small holes and use a zip tie). I sealed up the pinch welds with RTV when I was done. It took about an hour to do both sides. The wheels are 17x9 +18mm.
Dmopar74
How much taller is the pw over a stock 2500 front and rear?
