aam 11.5 locker
warwagon98xj
2014 2500 CCSB
does anyone make a lunchbox locker for the aam 11.5?
whatroads
2011 QC 4x4
Hemi 5.7 w/ 3.92
The only options I know of are ARB and Detroit. Of course, you could always weld the spider gears
homeguy
Calgary AB
2013 Big Horn
I'm very happy with my ARB lockers in both of my Jeeps. Engage them whenever you want or need them
SouthTexan
408 CTD
Eaton makes the Detroit Locker for the AAM 11.5.
If you are going to go with an on/off locker like an ARB. I would look into the AAM Trac-rite GTL. It is made by the same company that makes your axle. Its major benefit over the ARB is that it is a Torsen gear style limited slip differential when not engaged which makes it great for on road use, and a full on locker when engaged. The ARB is only an open diff when not engaged and a locker when engaged.
http://www.demandaam.com/technical-...cal-gear-with-electronic-locking-differential
krb686
Hemi 5.7l
TracRite® GTL - Helical Gear with Electronic Locking Differential | American Axle & Manufacturing | Aftermarket OE Parts
Wow really? So you get the best of both worlds there. Seems dam near perfect to me.
