2017 not your average Storm Trooper Rebel
Divinggumby
Divinggumby
SE PA / NJ
I got the lights mounted last weekend. I had to drill two holes and was hoping they would sit a little further back from what they do but it's not bad. I sprayed some paint on the fresh holes and then put a little bit of caulk on the washer and bracket to try to keep the water out so it doesn't rust up. It's much easier seeing at night backing up now. I wired them into the purple wire of the back up light bulb so they come on automatically when I back up.
I didn't realize the door came in that far but it just makes it.
Divinggumby
Divinggumby
SE PA / NJ
A little update. I miss my F150 seats cause looking cool doesn't mean they're comfy. I had to take the head rest off and put the rear one on cause they put your head at a horrible angle. I'm not sure if it's the way the seat broke in or how they made it but the passenger side doesn't feel as bad so I'll have to ask the stealership when I go for the 1st oil change about it. So far the rest of the truck has been good. I have 4,600 miles on it already, I think this would be the last Ram I'd own just cause of the seats and the way they did the interior since they don't have the room the F150s give you. I'm waiting for it to get warm and stay warm to do the HID conversion since I don't want to mess with the plastic trim while it.s still cold out.
I got a Bedrug mat for the back and I was expecting it to be a little different but it's still nice to have.
Divinggumby
Divinggumby
SE PA / NJ
I got the Hi-lift jack mounted on the rambox bar with using the Hi-lift jack mounts and a unistrut channel nut.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Cool. It took a little bit for me to realize I could do it this way since I was trying to figure out how to mount the jack in the bed.
The weight of the jack broke the inside of my bed so I had to take it out. Did those tie down rails come from the factory?
Divinggumby
Divinggumby
SE PA / NJ
I was tired of dealing with the ram cover so I sold it and got a truxedo lo pro roll up cover.
HolyRam
Cummins 6.7
Jack mount looks awesome! I need that
Divinggumby
Divinggumby
SE PA / NJ
I got her off road last weekend in Wharton State Park in NJ and found out she doesn't like any thing more than rumble in a road since the suspension isn't set up to handle any whoops. I broke the passenger side view mirror from branch hitting it when it was 25 degrees out so the plastic was a little brittle.
1-1/2-2' whoops on the one road.
Divinggumby
Divinggumby
SE PA / NJ
Yeah expensive fun. I'm taking the bike out in the future because it's cheaper to fix.
The videos from last weekend.
[yt]YtmXsAHnPuE[/yt]
Divinggumby
Divinggumby
SE PA / NJ
What sound does a moose make?
I was a little disappointed with the puddle lights.
derhicks
Looks great. Give it time. I went from an F-150 to a Ram. I'd never go back.
mjmck
3.0L EcoDiesel
I went from a slew of Fords to my RAM. I think RAM has come a LONG way from my buddies 07. Much more comfortable and refined.
I do miss the off road performance from my past fords (all FX4's) to my current bighorn. Best part is the MPG out of the EcoDiesel.
Divinggumby
Divinggumby
SE PA / NJ
Both have strong points and weak points. I never had the fx4 shocks but I would assume the bilsteins in the rebel would be a little better. the mpgs I'm not concerned about since it's a truck and the hemi actually has gotten 1/2 a mpg better than the ecoboost and I'm sure the ecodiesel is the same way when you calculate cost per mile since diesels will always get a little better mpg.
Divinggumby
Divinggumby
SE PA / NJ
I upgraded from the 285/70 Toyo AT2 to the 305/70 Nitto Ridge grappler tires. The bigger size looks much better than the smalled stock tires.
Divinggumby
Divinggumby
SE PA / NJ
