schroederMP
I have a 1993 Dodge Stealth. It is NOT the twin turbo/AWD model. Its the 3.0L SOHC. It is a 5 speed manual. 155,*** miles (will change)
The car is primer grey, only has the drive and passenger seats. I removed the back seats because they were junk. I have bedlined the floor in the interior.
The good
Stage 3 clutch/fly wheel.pressure plate-5k miles on it
New struts
New radiator
New plugs and wires
New half shaft
New tie rods
2nd set of tires (used)
Power window/Locks
New fuel pump
The bad
Could use a paint job
Body isn't prefect
No radio
Sometimes the syncos in the tranny will grind when shifting into 4th or 5th gear. Doesn't do it all the time.
Cracked windshield on passenger side...doesn't go all the way accros
This car has been taked care since I've owned it. Its has 1000 miles since the last oil change. I've changed it every 3k miles. It has never failed to start on my. I've driven it to Northern Indiana, Kentucky, Cincinatti. Not one problem. Its been my daily drive to work and back.
This car is NOT a show room car...so don't come expecting it to be perfect. But its reliable.
$2000 OBO...money talks
The good
New struts
New radiator
New plugs and wires
New half shaft
New tie rods
Power window/Locks
New fuel pump
The bad
Body isn't prefect
No radio
