Saseacasea
- Nov 25, 2016
- 60
- 22
- 2014
- 5.7 hemi
Asking $350 with shipping. This will include a belt, crankshaft bolt, and new seal, an addition $55.00 value.
I will take PayPal or local pickup only. PM me if you are interested.
Note**There is some small oxidation marks on harmonic balancer(very minor)-I have noted in pictures.Note, item taken out of package for picture purposes only. Brand new and never installed or used.
Inner and outer shells are available in aluminum or steel, and contain a steel inertia weight. This inertia weight has six (2-ring design) or eight (3-ring design) computer machined grooves to retain the proper durometer O-rings (dyno tested for each application).
A shorter serpentine belt is needed when running this pulley. 2009-2012 Trucks need a 77.5" 6 Rib Belt, and 2013+ Trucks need a 71.5" 6 Rib Belt.
**I will even throw in the 71.5" 6 rib belt for free(15.00)
Note**I have also included the Crank shaft bolt and Seal that will fit a 2014 dodge ram 1500 with this package, this is an additional $45.00 value
