I found the other day if you unlock your truck with the factory fob then press and hold the unlock button it will roll you front windows down
what about tapping your turn signal up or down just before it clicks and your signal will blink 3 times and stop. I like it for lane changes or merging.
.....And what does the center button on the drivers side of the steering wheel do ? (between the up & down buttons on the back side) ?
These are not really hidden but in evic you can change a lot of cool things a couple really nice ones are tilt mirrors in reverse and hill start assist. I love that the factory remote start chooses the correct climate control settings no matter what you had set when you jumped out including the seat Warmers and steering wheel heat.
$miley
I can't find the mirrors in reverse feature so I assume I don't have it?
That button moves you through your station presets for radio or sirius.
$miley
my 13 laramie wont do the windows with the fob unless I am doing it wrong? I didnt realize the middle button on back side of steering wheel went through the presets..nice!
Sent from my iPad using Tapatalk 2
