Power is made in these trucks at a higher RPM, IMO think your dealer is full of it. Plus the guys on the track wouldn't be trying to raise their RPM threshold if this was true.
What are you talking about ?????
1) The traction control button only turns it off ~ 1/2 way. You need a tuner to turn it all the way off.
2) The Tow/Haul button raises the rpm at which the trans shifts and the pressure at which it shifts, thus letting the engine spin up higher before the shift so the torque is better WHEN it shifts, and the increased line pressure lets is shift faster.
3) By letting the engine spin up higher, it also lets it make more power (yes, these engines do like rpm).
The reason the guys on the track want to raise their rpm threshold is so the engine can make even more power from increased rpm than it does when tow/haul is engaged. Tow/haul only raises rpm a little compared to what it could be raised if power was the intent vice better shfiting under load.
The dealer is indeed correct.
