2012 Ram Expresss Drop Done
gr8ridn
Kern Valley
Nope it rides stiffer, But corners great. You can feel every bump in the road.
If mine was a 4x4 I wouldn't have installed these, hinders Off-Road performance. Would have left the stock front one on and installed Quick Disconnect Links.
Your truck looks great! I have been considering the same setup with the Hellwig bars and deluxe McB 2/4 kit. I don't quite understand the bars stiffening the ride that much on straight roads. Are you referring to additional friction of the sway bar bushings or is it the reduced independent action of the front suspension?
I have installed performance sway bars before without significantly reducing ride comfort on previous trucks and cars. Maybe the all coil suspension has changed this.
Thanks for any feedback before I take the leap.
Similar threads
