Dropping a 4x4
StoneDude76
West Chester,PA
1d69e41a6fe89682d8eef19745204856.jpgWhat are my options? I'm thinking of lowering my truck. It's a 14 Blacked out Express 5.7, 4x4, 8 speed.
Sent from my XT1080 using Tapatalk
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Ground Force 2/3, Mcgaughys 2/4 using spindles, or Mcgaughys or Ground Force 2" rear coils if you just want to level it out.
StoneDude76
StoneDude76
West Chester,PA
How rough is the ride with these kits? I'm still on the fence. And how easy is it to install?
StoneDude76
StoneDude76
West Chester,PA
I see that Moes has those kits Hemi450hp mentioned but they say for 2wd. Is there any difference?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I run the Ground Force on mine. Ride is a little stiffer than stock, but in no way uncomfortable. The 2" rear coil kits and mcgaughys spindle 2/4 are pretty close to stock when it comes to ride quality.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
In all honesty, I would go with the Ground Force 2/3, which is the only kit we don't sell.
N1ck
Regina Sk
I was very happy with the 2/4 spindle drop kit i used on my 14 sport.
StoneDude76
StoneDude76
West Chester,PA
I have some decisions to make. Grrr.
13bighorn
Ontario Canada
I'm thinking I have some to make aswell. Looking to get the rear end down 3 or 4" on my '13 4x4
charonblk07
Calgary, Ab
F1-A forged 349ci
The spindle drop keeps all the factory suspension the same, the CVs just are at a steeper angle; ride quality is unchanged. The spring drop is a slightly stiffer ride and there are suspension alignment changes but there are no major issues.
13bighorn
Ontario Canada
Can someone with the 2/4 mcgaughys kit tell me what it is from ground to fender in the rear? Debating that just don't want any clearance issues with tires
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I just measured my 2015 crew cab 4wd with the Ground Force 2/3 and 305/50/20 tires. Front is 34.25" and rear is 35".
tones2SS
MA
SO,.....when you say that the rear spring drop brings suspension alignment changes, what do you mean exactly?
I have a 2016 Ram Sport 4X4, regular cab and am interested in the McGauphy's 2" rear drop springs, just to level off the truck some. I should be all set with just those correct? I don't need any other suspension modifications, would I?
Thanks!
charonblk07
Calgary, Ab
F1-A forged 349ci
There's no issues with a 2" rear level. You only start having issues at a 4" rear drop with the control arm alignment and length and at 6" you need to rethink the axle brackets.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Thanks!
I would look into the Ground Force 2" rear springs instead of Mcgaughys. The Mcgaughys were designed for 4 door trucks, so they only give 1" rear drop on the regular cab trucks.
tones2SS
MA
Thank you guys. I appreciate the info. :favorites13:
Hemi,.....do you sell those springs you were referring to, the Ground Force 2" rear springs drop?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Unfortunately we dont. I've just seen quite a few regular cab guys buy the McGaughys 2" springs and come back disappointed at only seeing a 1" drop. Ground Force makes both 2 door and 4 door specific 2" rear drop springs. They will get you a true 2" drop.
tones2SS
MA
Thank you sir!
I appreciate your info here greatly. :favorites13: :favorites13:
