Pictures would be appreciated
RamFan2
I've been thinking lately about what I want to do with the rake on my truck. I had originally wanted to lift the front with some coil spacers, but I'm not completely convinced since I've seen some damn fine lowered trucks. If i go low, i'm thinking about a 2"/4" drop, but i'm worried it'll be too low for me.
My main concern is if (when) i get leveled, I don't want to be nose up when I have a load in it. At most, it'll be a couple dirt bikes and a few full ice chests, but not always that much.
Any input would be welcomed, pictures would be great. Thanks.
ramthis9501
Oklahoma
5.2 V8
Removing your overloads will help with the rear end. I did that with 1.5" drop shackles and it is pretty much level. No sag in it either with some weight in the bed
Stangshcky12
Oshkosh, WI
5.9 Cummins
4th gens have coils in the rear
Should you raise the front or drop it you could get timbren bumpstops
That way should you have a load that would drop the rear the timbrens would help
No airing up or down, just set it and forget it basically
blackout11
alpharetts GA
2011 R/T
I have mine lowered 2'' and ive had dirtbikes in the back with n/p now a trailer or boat that might be different here it is with 2'' drop
S
scotts2012ram
Guest
The 4th gens seem to sag less maybe just me. Mine with a forman and 500 pounds of deer and acc.s. Very little sag now same thing in my 95 gmc 1500 hello stars
Blackout I'm coming for my truck haha
R
RamFan2
Seeing trucks like this is why i want to go down. Looks good.
What kit did you use?
LWP427
2012 R/T
Lowering
RamFan2. What kit or parts did you do to lower it. Was it 2" in front and rear?
Larry.........................
R
RamFan2
I haven't lowered mine yet. If I do, i was looking into the Belltech 963sp. It's a 2" drop in the front and 4" in the back.
blackout11
alpharetts GA
2011 R/T
N/p ill leave the payment book on the seat lol
S
scotts2012ram
Guest
Blackout I know that one I want a r/t so bad but I have to have a 4 door. I wish they'd come out with a quad cab r/t like they did with the srt10. I'd love a 6.1r/t in a quad cab that would be sick
BigH0ss
Banned
Damn Walt I guess your rig is the most wanted of the twins! :'(
WhiteExpress
Midland, TX
Every time I see a lowered Ram, I think "It can't be THAT bad of a ride, I should just do it"
blackout11
alpharetts GA
2011 R/T
Ya just the rear and it rides the same if not better then stock
R
RamFan2
So I've been going back and forth trying to decide on the 2/4 drop or just 2" in the rear. After researching the crap out of this, I found that a bunch of people were having issues with the rear end shifting to one side because the Belltech kit doesn't have new sway bar end links. Anyone else hear of this?
quietpeen
2021 TRX
Hellcat
ahh just lift it and forget all these issues...LOL
ARMYRETIRED
Greenville, NC
6.7 Cummings Turbo
Or get a McGaughy's and buy the belltech shocks seperate. not that big a difference in price. McG kit comes with bracket to center axle.
WhiteExpress
Midland, TX
It is a fact, if you lift or lower an axle with a panard bar, it will shift one way or another. It's just how it works. You can compensate for it on some vehicles by drilling a new mounting hole.
McG's is the only lowering kit that I know of that gives you a bracket to relocate the panard bar. It has absolutely nothing to do with the rear sway bar though.
The other option is having a bar modified / custom adjustable bar made.
ChloeBrooks
