I just used the Daystar 1.5 spacer, lifted 2.5" overall though.
How tough was it to get the spring back in?
It's a PITA! Use more than one person and alot of patience.
Had a local shop that does all the new dealers lifts do install. So not sure. They put them in, I put tires on and drove for alignment.
Not what I wanted to hear, but thanks. I installed some on a 98 GMC and they were a PITA, I was hoping it was easier on the Ram, maybe a different coil bucket design or something.
How much did they charge?
Did you ever install it? How much lift did you actually get? And did it change the ride? Thanks!
I installed 2.5" spacers on my 2wd 1500. Definitely need to use spring compressors to get them back in.
Thanks, I went with Top Gun Customz.
Hello everyone am new to this forum, I got a question about this, I did a 3 inch level on my truck but now the ride is too bumpy, anyone know what I can do to avoid that
For all those running 2500 shocks, where do you get the bottom adaptor for the 2 screws and how do you press it in?
