Andler2008
I have a 2014 Ram 1500 Express Crew Cab in white. I just got a set of Helo HE879's for $450 with tires. 22x10 on 305/45/22. They clear just fine, I would just prefer to have it leveled. I only have 50k miles, shocks were just replaced by the dealer prior to purchase so I'm not adding Bilsteins at this point.
I got the 2.5" spacers off Amazon for $60, and I actually am impressed at the quality and the way they mount. You first install what I believe is M12 if not M14 cap screws in through the bottom of it. they sit about .5" down into the recess of the spacer. Then you put the space onto the shock, after you spin the whole strut assembly 180 degrees. Install the original nuts for the strut mount, then put the strut into the strut mount for final assembly. The nuts, washers and lock washers are all SS which I thought was a nice touch.
However, this is where I got stuck. I removed the caliper assembly, including caliper mount, Tie rod end, sway bar link, ABS sensor and separated the upped ball joint. It was a struggle to move the LCA low enough to get the Clevis mount of the strut into its little pocket, and I could not get the clevis seated enough to get the bolt in. I was able to push the LCA lower than the strut, but when bringing it back up, there was no point in linear progression that allowed a straight shot for the bolt to go through the clevis and into the bushing.
Has anyone experienced this issue, or know of this type of issue and what possible fixes or modifications need to be made to get them on? I typically don't ask for help, I just get it done. but I'm completely stumped.
