Another level kit post, 2013 bilstein 2.8"
Synolimit
Ohio
First off if you're gonna lift your truck do it brand new!! Truck has 700 miles on it and every bolt came right off and the upper control arm didn't need pounded out or a fork used!! What a dream!
Second, my truck is a 2013 express quad cab 4x4 hemi with a stock height of 37" front and 39.75" rear (no sun roof or added weight from extras). I also installed 1/4" gorilla spacers to prepare for 35x12.5's on the stock 20x9's going on in the future. The stock measurements for the upper control arm and front sway are 0.65" UCA and 0.60" sway bar.
After the 2.8" lift the front sits 39.875" and the rear again sits 39.75". I'm not 100% sure yet but I might add a 0.75" rear spacer to get some rake. As of now though I think it sits perfectly level with the eye. The UCA now sits 0.90" from the tire and the sway is 0.80".
The stock tire being 275mm equates to 10.83". Going to a 12.5" tire it looks like ill gain 1.67" in width. Divide that by 2 and the tire should come in 0.835". For the UCA it should fit since it sits 0.90" away but the tire may rub the sway bar since it will be 0.035" over what's available. But now of course every tire is different and not all 35x12.5's are really 35x12.5 so we'll see.
Tomorrow ill get an alignment and remeasure everything!! But as for now it drives straight and true. Only thing noticed is the bilsteins are a little stiffer which you can feel going over bumps.
Stock
Lifted
WhiteExpress
Midland, TX
Looks good. I'd get a .75 or 1" rear spacer personally. I don't like no rake on a 4x4
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
I like it! Kinda makes me wish I woulda went with Bilsteins!
S
Synolimit
Ohio
SOB!!! I think I have to redo everything!!!!!!!!!!!
I went dust boot, strut mount, washer, hex nut. Pretty sure it should go washer, dust boot, strut mount, hex nut. Found a guy where after 4 months his piston rob like blew up through the strut mount. Pretty sure that's why!
Stroked
Beloit, Kansas
Looks good! The alignment brought mine down 3/4 of an inch.
Elroy
Looks perfect
S
Synolimit
Ohio
Fixed the washer setup, me and this time a buddy knocked it out in an hour!
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Reading the directions is always a good idea haha. Glad you caught it before **** hit the fan though. I would also rather have a little rake in the back vs the inverse.
S
Synolimit
Ohio
Just ordered TGC 0.75" rear spacer so when they come ill get an alignment and remeasure :)
Fatboy1989
