Install of Topgunz rear spacer?
gibby252006
Just looking for some tips on how to install rear spacer easy. Any tips will be helpful. Thank you.
reb0957
Broussard, LA
5.7l
The rear spacers are easy. Get 2 jack stands preferably the tallest you can find and use the max height setting and support the frame. Remove tires. Place jack under pumpkin and support lightly. Remove sway bar link on each side and the lower shock mounts. Move lower shocks clear of the axle. Use jack stand to lower axle pull springs clear. Follow topgunz instruction for their spacer. Install in reverse.
G
gibby252006
Thanks just wanted to see if anyone had any tricks to the trade. Thanks I did read the DIY which was helpful.
jake09
Guess you could also just use some spring compressors and slide it out also??..maybe enough for a small spacer
G
gibby252006
Well i was going to get one but from what i seen its easy that way.
reb0957
Broussard, LA
5.7l
I did forget to say that I used a spring compressor to reinstall the coils. After fighting the front all night Friday night I was tired. Autozone didn't charge me anything to borrow them other than a security deposit.
G
gibby252006
It's just going to be the rear. I'm doing bilstein 5100 in front.
Ramchowder
