Lifting my 2012 hemi
Jdbol
I have a 2012 hemi 1500 crew cab 2wd and am shopping for lifts. I found the CST 7" and wanted to know if anyone has this lift on their Ram and what they think of it. I know there's other manufactures out there like Rough Country and I just wanna know what's the best bang for the buck.
Wandell
Cummins 6.7
The CST lift is great quality. With a 4x2, your options are limited. Basically you can go with the CST lift or add a leveling kit (or adjustable coilover shocks) and/or a body lift.
J
Jdbol
Would you recommend the CST or Blistein or ProComp shocks?
TXKID
Houston, TX
CST is probably the highest quality out of the 3 as far as I know but they will run you a little more. I'm not too familiar with the bilsteins, as far as other people are saying on other forums though the pro comp shocks are still high quality and much better than the stock shocks
12TrueSport
San Diego, CA
2015 True Blue Pearl Sport
HEMI 5.7
Bilstein does not have a shock application for the 2012 4x2 with the CST 7'' lift. You will have to go with CST's shock or one of the procomp models. I'm looking into this kit as well. I found the kit, the wheels and the tires, now I just need to find the $$$$!
Reo Cook
Houston
5.7L HEMI
You can run shocks for a 2500 to get the extra travel and save a ton of cash versus buying the cst brand shocks . That's what I did with my spacer. Next step for me is the cst 4" spindles and I'll have my 9" total with my 3" body lift
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
The CST lift and shocks are gonna be the best bang-for-buck on your 2wd application. They have a really good product! If you had a 4wd I would recommend the Bilsteins, but the CST shocks are very well made!
arod412
Philadelphia
not trying to be rude but i'm very curious....besides looks on the lift....is there any reason why you got a 2wd then decided on the lift?
Wandell
Cummins 6.7
The same reason most people get a 4wd and lift it.
Wandell
Cummins 6.7
Also, I believe the CST lift for 2wd's uses OEM length shocks. So you can use any OEM replacement.
hemipowerv8
You could just use the 4" spindle from CST and their rear springs that lift the back 2.25" (I think...maybe 1.5" I forget) and be nearly level and also be able to run 35" tires...to me the 7" kit seems a bit much...
grzmnky
im leaning towards the 4" spindles myself and 33's
BULLRAM
HOUSTON TEXAS
HEMI 5.7
You are correct, the CST's and all our 2WD lifts use the stock length shocks, so there are a lot of choices, from stock, to performance, as long as they are stock length for a Ram
12TrueSport
San Diego, CA
HEMI 5.7
My truck is in the shop right now getting the CST 7'' Kit installed. I'll post up in this thread when it's done. I went with a 20x9 wheel 4.53bs and -12mm offset.
Is it a bit much?
I'm 6'5'' and think this lift will fit me perfect..lol!!
Stay tuned.
Wandell
Cummins 6.7
A 9 inch wheel with 4.5 inches of BS seems to be the most common spec for the fourth generation Rams.
I can't wait to see some pics!
12TrueSport
San Diego, CA
HEMI 5.7
Just started a new thread with the pics. I really like this setup!!
ChloeBrooks
