rc lift
1500ram12
5.9L Cummins
Just ordered the 2.5/1.75 lift from roughcountry. Told my wife I was going to keep this one stock. oh well.
quietpeen
2021 TRX
Hellcat
if you are are on forums there is no such thing as keeping your truck stock...LOL
WhiteExpress
Midland, TX
I'm really surprised I'm still stock height after like... 5 months?! WOW!
durango4819
DE
4.7 V8
i had the RCX leveling kit on my truck a while ago and just a little hint from my experience, if you put the rear spacer in your truck still wont sit level, just higher all around. heres a pic of mine with the same kit on....see how the rear sits higher? id just install the front spacers if you want it perfectly level. it is an overall nice kit though. didnt affect my ride quality at all. just trying to help!
quietpeen
2021 TRX
Hellcat
yea they really shouldn't call it a leveling kit. Honestly your truck still looked good with it installed. A slight rake looks good imo, but the stock rake is horrible
durango4819
DE
4.7 V8
thanks, and yea it wasnt the most noticeable rake in the world but definitely noticeable looking at it straight on from the side like that. heres another one where you cant tell (i really dont miss those quads lol.) and if i remember correctly my kit was a 2.5''/.75'' versus his with the 1.75'' rear. is that how it comes now? or is that a typo? hope all this helps OP.
1500ram12
1500ram12
5.9L Cummins
not to concerned about having it leveled just sitting a bit higher. I'm horrible with spending money on vehicles. I don't think I've owned one that I haven't added something too. Stock is not my thing. I will say this is that quickest that I've started buying things for a vehicle. I usually wait about a month not a day.
1500ram12
1500ram12
5.9L Cummins
Did you buy the kit that came with the body lift? Because the rear lift in that is .75 but the standard kit the rear shows that it is 1.75. What size tires are you running?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The raked look will make it level when towing and not ass down under load. Either way the truck will look good.
durango4819
DE
4.7 V8
nope bought just the leveling kit itself and it came with a .75'' rear spacer. those are 285/70/17s. i did add a body lift later on and replaced the front spacers with Bilsteins and i still have the rear spacer in.
1500ram12
1500ram12
5.9L Cummins
Lift is here. Hopefully going in friday
1500ram12
1500ram12
5.9L Cummins
first attempt at install failed. only had 2 hours of free time and couldn't figure out how to drop the arms low enough to slide the spring assembly back in. Trying again tomorrow. going to pull the brake caliper off hopefully that will give me the extra drop I need. Plus I have more time. Any info is greatly appreciated to make this go faster.
quietpeen
2021 TRX
Hellcat
Did you use a coil compressor?
1500ram12
1500ram12
5.9L Cummins
I have one, didn't try using it. didn't think i was going to need it for the front.
quietpeen
2021 TRX
Hellcat
Yea use it and you should be able to get them in
ChloeBrooks
