AzRamLover
- Oct 29, 2014
- 433
- 98
- 2014
- Hemi 5.7
[2014 Laramie CC SB 4x4 w/ 8spd & 3.21s]
Did a search but haven't found any sage advice on this just yet. My thoughts below - feel free to add your $0.02 and if I've missed anything?
No speedometer differences as I believe the dealer can correct for the appropriate sizes (please correct me if I'm mistaken); I also selected the lightest wheels I could aesthetically stand for the purposes of this analysis.
20" (P275/60/20 Michelin LTX M/S2)
Revs / Mile: 611.6
Engine RPM @ 70mph: 1,535 (70 miles / hr x 1 hr / 60 min x 611.6 revs / mile x 3.21 axle ratio x 0.67 8th gear ratio)
Wheel Weight: ~32 lbs (searching forums)
Wheel Cost: $0 (included w/ truck)
Tire Weight: 41 lbs (Tire Rack)
Tire Cost: $223 ea (Tire Rack)
Tire Diameter: 33" (calculated)
18" (P265/70/18 Michelin LTX M/S2)
Revs / Mile: 618.8
Engine RPM @ 70mph: 1,553 (same calculation except 618.8 revs / mile)
Wheel Weight: 25.25 lbs (Mamba M14 18x9)
Wheel Cost: $175 ea (Tire Rack)
Tire Cost: $199 ea (Tire Rack)
Tire Diameter: 32.6" (calculated)
17" (P265/70/17 Michelin LTX M/S2)
Revs / Mile: 638.4
Engine RPM @ 70mph: 1,602 (same calculation except 638.4 revs / mile)
Wheel Weight: 22.8 lbs (American Racing AR899)
Wheel Cost: $139 ea (Tire Rack)
Tire Weight: 42 lbs (Tire Rack - surprising increase here but there's more tire)
Tire Cost: $197 ea (Tire Rack)
Tire Diameter: 31.6" (calculated)
Net 20" => 18"
Wheel & Tire Weight: (6.75 lbs) per corner
Replacement Tire Cost: ($24) per corner
One Time Cost: $175 per corner + installation, TPMS, etc.
Truck Ride Height: (0.2") ([32.6" - 33"]/2)
Engine RPM @ 70mph: +18 RPM
Net 20" => 17"
Wheel & Tire Weight: (8.2 lbs) per corner [22.8 lbs - 32 lbs + 1 lb increased tire mass]
Replacement Tire Cost: ($26) per corner
One Time Cost: $139 per corner + installation, TPMS, etc.
Truck Ride Height: (0.7") ([31.6" - 33"]/2)
Engine RPM @ 70mph: +67 RPM
I think 17" are the right choice also because of the wider variety of tires available at lower cost and increased impact protection for the wheel.
The decreased unsprung mass, lowered ride height, and increased cruising RPMs should *theoretically* make a fuel economy difference but they're all so small that I expect they'll just get washed out in the noise.
Anyone have any additional thoughts or guidance?
Revs / Mile: 611.6
Revs / Mile: 618.8
Revs / Mile: 638.4
Net 20" => 18"
Net 20" => 17"
