RamBox Revolver X2 Install & Review
Danny5
Surprise, Az
Cummins 6.7
I've been looking at all the available (expen$ive) tonneau cover options for the Rambox model since we bought her new in November of 2016. At the end of February, we decided on the Bak Revolver X2.
Now, there are not a lot of pictures or video on installing this tonneau cover on a Rambox model. So going into this install, I felt a little apprehensive. Hopefully these pictures will help other Rambox owners should they choose this pretty cool cover!
No unboxing pictures. I've seen other truck models of the X2 unboxed, and it was almost exactly the same. 2 rails, a bag of hardware/rubber, and the tonneau rolled up. First step is to break down the factory rails by removing the adjustable tie down cleats and the end cap covers.
A couple of different thickness bulkhead seals are included in the kit. If you bed is bare, like mine, then you install the thicker seal
These next shots are the rails you install into the factory rails. Be careful as they bend easy! I put pressure in the wrong spot and put a bend in one. argh!
They install into the top channel on the factory rails
The instructions warn that this is a tight fit, and they weren't kidding. Not a chance getting them in without lubrication. The instructions recommend soapy water. When this failed, I tried pure car wash soap. And when that failed, it was WD40 to the rescue. I used a block of wood to help get them all the way in.
Do NOT push on the top of the rail that sticks out, only push on the part that slides into the factory channel!
Push them in until you can push no more. I used the aforementioned block of wood and a hammer to tap the rail the rest of the way in until the plate touches the front of the bed. The instructions warn that a drop in bed liner will have to be cut for clearance. *sucky*
Now you can slide the provided straps and the factory tie down cleats back into place.
Drop the tonneau cover on your installed rails and cut the saran wrap.
Roll it out and check fitment. This is when I discovered my fitment issues. The tonneau cover and installed rails were interfering with tailgate operation. Since these aren't clamp on rails like most trucks, I had to figure out other ways to get some height out of them.
Out comes the electric ratchet and a 10mm socket. I loosened all the factory bolts on the accessory rails, pushed them up in the rear only for more clearance.
Why not lift the rails all the way Danny? Because you still want the bulkhead side to seal! :naughty:
Now with the rails raised, I can close the tailgate and adjust the tonneau cover. This is when I noticed some "strange" engineering???
First off, the supplied rails stick out of the factory rails. This means those end caps you removed in the beginning won't be going back on the truck.
This gap at the front of the bed is scary! If you have a drop in bedliner, this would probably match up nice. As it was, I cut more of that bulkhead seal and stuffed it in this gap...
Say it ain't so! I was missing the install hardware, so I ran off the hardware store and bought nuts and bolts. I have already spoken with BAK and they are sending me the correct hardware. For now, I have these cranked down good and tight. (By hand, not with an impact!)
I slid the strap mounts so they are slight under the tonneau when fully open. These I did use my electric ratchet with a 13mm socket.
This is a decent shot of the alignment. The instructions state to line up the back of the tonneau with the end of the rail. However, the passenger rail sticks out about 1/4" more than the driver's rail. My fitment was best by lining up with the driver's rail.
And no interference with a rambox, tonneau cover open or closed!
It's a tight fit, and not exactly the water tight seal I was hoping for. There are large gaps, probably more due to the design of the rambox than any fault of Bak. The one part that bothers me the most is the height adjustment of the rails still wasn't really enough. The tonneau cover contacts the top of the tailgate when closing. The only way to close with the tonneau in the locked position is to really slam it.
I also bought a tailgate seal kit, and used a lot of this to plug holes at the back end of the cover. It won't be perfect, but I should be able to put things in the bed without them getting soaked.
Final thoughts? This cover is a huge improvement over it's predecessor, and I would buy it again. I just wish I knew what I was in for ahead of time.
And that's why I wrote this! :D
quietpeen
2021 TRX
Hellcat
Looks good and nice write up
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
Great write up, thanks. I've been looking at this exact tonneau
Sent from my XT1635-01 using Tapatalk
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
Thanks for the write up and photos. I wanted a BAK cover....
PhillyGoat
Pacific Northwest
Great write up! I have the same cover (no rambox) and the only issue I had was trimming the drop in bed liner so that the rails went all the way forward. To do that, I used a dremel with cutting wheels. I went through a few of them, and it more melted through the plastic than cut through, but it still worked like a champ. One thing I could have done better is put a barrier up to prevent the aforementioned melted plastic from adhering to other parts of the truck. Once that was done, the instructions were well written and easy to follow. Including the time to trim the bed liner, it took 35 minutes from start to finish.
The last step for me, which was not in the instructions, was to super glue the small gap where the front corners meet. This created a much more watertight barrier. I installed the liner the day before driving from South Carolina to Seattle and nothing got wet that was in the bed, even driving through a few storms.
Another good feature is that the cover is rated to hold up to 200 lbs on top of it. That means that if I am feeling a bit adventurous (as I have once in the past), I can stand on top of the cover while it is closed. Not that I ever really need to, but there is that option. I also like that it is an aluminum frame, so with the tailgate locked it provides a more secure barrier than a canvas cover.
RDHemi16
Nice write up. Do you guys have an opinion on the most watertight tonneau cover for the short rambox? I almost thought about trying to modify one of the big hard one piece hinged tonneau covers to fit. I'm mainly worried about luggage and items when we take long trips.
D
Danny5
Surprise, Az
Cummins 6.7
Zero concerns with luggage in the back of the truck. I've sealed the tailgate gap, and water, at most, would be a few drips. Plus the rails of the bed would keep water away from the luggage itself.
However, there is one tonneau I was looking at that would definitely fit the bill.
Look for tonneaus that sit on TOP of the bed rails, like Truxedo. I think they look ugly as sin, but since they are on top of the bed instead of inside it, I think they would give the ultimate in water protection.
Rickent
Illinois
Nicely done and so very helpful. Thank you. Someone had needed to do this.
Ramchowder
