Under Dash Foot well Lighting
mocaby73
illinois
Yep there the ebay ones. The adhesive on the back is crap though you'll have to use some other adhesive.
tjones524
Ofallon, MO
Put those in my truck tonight.
Looks brighter then my walmart strips, that's why I suggested those, they utilize 5050 chips.
Looks a bit more blue then mine, maybe it's the camera.
Well, mine is white with blue tint.
mocaby73
illinois
They are a little blue. Might have to change them. I have a very bright white led dome light I cant stand if things don't match.
tjones524
Ofallon, MO
Same here, I have a pretty bright 212-2 led dome light, it's 9 x 5050 leds, at 0.24W per chip ( 9 total ) it's 2.16 watts.
It's more whiter then my floors tho.
The newer Samsung 5630 LED's are 0.50W per chip, at 0.50W x 6 as linked below, it's 3 watts, so a full watt brighter just about.
So for those wanting a brighter alternative, seek LEDs containing 5630 leds.
Festoon 569 578 562 212 2 211 2 214 2 Rigid Loop Samsung 5630 LED Bright White | eBay
The listing shows 6000k but looks whiteish.
It's surprising how difficult it is to match leds sometimes.
Edit:
http://www.ebay.com/itm/White-9-SMD...Parts_Accessories&hash=item20dde4b6b4&vxp=mtr
Found an even brighter solution, an astonishing 600 lumens, 9x 5730 LEDs. Wow lol! and a bit newer led then 5630.
It's labeled as Xenon 6000k, should have a blue tint for sure.
Yo Nadz
St. Louis, MO
Hemi 5.7 Sport Crew Cab 4x4
I may have to try this also. I miss the floor lighting my previous Lexus had.
hawg44
ward, arkansas
No need for t-taps...found the pigtails for footwell lights yesterday...passenger side requires you to remove lower glove box( open and squeeze sides...look around inside..I found my pigtail..yellow/violet on 2013`s.) then crawled upside down under drivers side..found same pigtail taped to a wire bundle..have not tested yet...but do believe its prewired..as for the wiring for lights to come on with rotary switch..not sure...too damn cold to play around just yet..
where did you find the pigtail on the passenger side? i found the one on the driver side?
colport833
Ontario
2022 Ram 1500 Classic
hemi
On my truck I opened and dropped glove box...back in there..near the heater box..
ramenthusiast
Banned
W. Palm Beach, FL
2012 Crew Cab Sport
It's got a Hemi!
Great thread, will have to look into this. I wanted to share one caution, though. When it comes to poking around the CANBUS system on these trucks and tapping for power you have to be very careful as some circuits are more sensitive than others. I found this out when I tried to tap into a hot lead in the center of the dash that was in a connector for the A/C controls. Apparently the A/C controller did not like that and it went bad immediately. The A/C controls still worked, but it would no longer remember what position it was in after turning off the truck. I was lucky that the dealer warrantied it for me.
colport833
Ontario
hemi
when and if it warms up..I will only be adding lights (leds) to harnesses that dont have light already..footwells..on the 2013`s there should also be a yellow wire with light blue tracer..that has "juice" for mirror vanity lights, map lights, glove box light..just add a switch..add your own aux lights(led)
Copatlarge
is there any of those wires that just turn on when the lights are on? i want to add lights too but want them when the headlights are on, or parking lights. etc. I don't want to have to have a seperate switch...
Thanks
Bill
7777xm
Covington, GA
Mine has oem lighting, it's a big horn, maybe that has something to do with it.
I wonder if the lower trim models have the harness available and just hidden
Copatlarge
id be curious to find out myself...I added some bed lights, may just run them to the dome instead of a switch..
2robinhood
2016 Ram 3500 SRW crew cab
6.4l gas
Does this wire become hot ( turns lights on ) when you unlock the doors using the key fob ?
