2012 4x4 front gear swap
Marc1982443
Southern Maryland
2012 big horn cc
I was told by dealer that I can change my front gears as the front dif is not serviceable. I have the 3.55 and want to go up to the 3.92. Does anyone know if this is possible or am I stuck with 3.55?
Etroze86
Grand Forks ND
If you swap out the whole axle yes its possible but that is $$$$$.
TXKID
Houston, TX
Yea it's why I haven't swapped out 4.56 gears yet
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Same here. I would rather wait until Yukon, motive, etc. come out with the "drop in" replacement gears.
fasthemiram12
Eagle 5.7 vvt
It would be a carrier/ring and pinion and install kit combo the would be prolly in the 800-1000 range anyway.
ChloeBrooks
