4.10 gears
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Rams pick up the speed after the gearbox, so the gears do not effect the speedo, only the tire size.
Correct and you can have dealer adjust speedo even if you cannot use tuner or do not have one for those that can.
$miley
glass3222
Central PA
$miley
You would only need to do that for different tire size, not for changing gears
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Yes that is why I said correct. Tire size causes issues with speedometers not gears on Ram anyways. The tuner allows you to.change gear ratio but I am not sure what the point is.
$miley
ramtruck4life
canada
gearing
hey guys im new to this think but i got a 2010 ram slt 4x4 with a set a 20s on it,
but i put a leveling kit on it with a set of 33x12.50x17 on it and was kinda thinking about gearing not like the hemi needs it but it would be nice to light them up a little more.. my dad has a 2011 outdoorsman and it seems like hes truck has way more torque... hes always sideways and burning tires lol
can someone help me out here
thanks everyone
jlb
MT
CTD
I wish I had your dad's problem lol, I have a similar truck (qc hemi outdoorsman), but can't get the rear tires to break loose in a straight line launch at all, unless it's wet, etc.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I disagree I have 4.56 gears and nearly 35" tires and I can peel out anytime anywhere both tires too since I have an Auburn. Intake makes it even easier but overall gears are the best mod possible IMO.
$miley
SILVER_BULLET
$miley
Do you have any kind of tuner? Because I have an rt so I have the 2600 stal and 4.10 gears with like 31" tires and I can barely get a chirp mostly because of the torque management
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I have Hypertech tuner which I run set to stock and only use for my speedo and delaying the speed MDS kicks in. When I tune my truck with Superchips or Hypertech it idles poorly.
$miley
ramtruck4life
canada
I wish I had that problem too haha
2012 Dodge Ram
Hey guys I'd like to be rid of my 3.55's as well. I don't plan on going any bigger then the stock tires so what would you guys recommend in that situation? 4.10's or the 4.56 still? I do mostly hwy driving back and forth to work but the 3.55's gotta go. My 2010 had the 3.92's which should be the minimum in these trucks i believe. Thanks for any input.
