code po507
borderram
Has anyone got this code yet. It is for IAC high rpm unexpected.
jwheeler
Washington
I'm sure someone, somewhere has. Do you have that code?
B
borderram
I do cleared it once and it came back. I have no vacuum leaks anywhere.
jwheeler
Washington
If you are positive there are no vacuum leaks, it is likely a throttle body problem. It is what regulates the idle speed.
