engine light
TED
I have a 2015 dodge ram 1500 4x4 with 23000 miles on my hemi. the engine light keeps coming on. I brought it to the dealership yesterday and they said it was a misfire on cylinder 6. they put it on the computer and everything came back good after clearing the check engine light, Today my check engine light is back on what gives. Someone please help with any information to fix my problem.
Punishher7
What is the code? That may lead you to an easy solution.
et todd
my 2016 did this.what oil are you using?i use 5 20 but added some lucas to get rid of the hemi tick after about 50% oil life i got a engine light and noticed it wasn't going to eco mode on the cluster.thought it might be the oil to thick and had a lifter issue so i bought oil for the oil change but right before i checked the oil i opened the fuse panel under hood and pushed all the fuses down they were not all seated all the way. anyway cranked the truck and no light i changed the oil anyway with no lucas this time and after 3000 miles all is still good.
T
TED
There's no code. Full synthetic
RamCares
Michigan
n/a
n/a
Hi TED,
Have you let your dealership know that the light has come back on so they can address it further for you?
Kori
Ram Social Care Specialist
